Question about Gateway GM5472 PC Desktop
My gateway 5472 won't power up ..i have tryed the power coard and that won't power eather
Try another gate way
Posted on Apr 13, 2014
Gateway 5472 won't power up
You must register some sounds and usual noise from the case. If you consider that power supply works, try to unplug all unnesessary parts, and remain with CPU+Graphics+Memory. You are now closer to eliminate the current problem.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Apr 13, 2014 | Gateway GM5472 PC Desktop
Hey, i have a gateway gm 5472. when i try to boot the computer up, firstly, i have no video or sound, the led power light does not come on, but the fams run. I have a MCP61PM-AM motherboard in it with Amd...
I would have suspected that your RAM needs to be removed, cleaned & then replaced which more often than not sorts out the problem you have described.
But since you mention the power LED not working, I suspect that you have a faulty power supply.
Try connecting a power supply from another working PC to see if this solves the problem.
If so, power supplies are relatively inexpensive & shouldn't set you back more than $20-$30 for a descent unit.
Best wishes,
Graemevm
Apr 03, 2011 | Gateway GM5472 PC Desktop
Hey, i have a gateway gm 5472. when i try to boot the computer up, firstly, i have no video or sound, the led power light does not come on, but the fams run. what could it be
unfortunately, this sounds like you may have some dead hardware, try unplugging everything from the motherboard, and only leave the cpu, one stick of ram, and plug the monitor into the on board port (remove the video card).
Now try to boot the pc.
If you have no luck, try the ram in a different slot, or try a different stick of ram.
If you still have no luck, try the cpu in another motherboard to find out if it is faulty.
If you can get your motherboard to boot with one stick of ram and the cpu in place, turn it off and start adding components one by one, booting up each time to find out which piece of hardware is causing the failure.
Apr 03, 2011 | Computers & Internet
Gm 5472 won't turn on
This either an issue with the power supply or motherboard. The best way to test is to replace the power supply and try to power it on to see if it works.
Something else you can try is, unplug all cables from the PC, open the case and the plug only the power in, turn it on and check to see if the fans turn on. If the fans turn on then it's most likely an issue with the motherboard but the best way to test is to replace the power supply and test.
Hope this Helps
Mar 08, 2011 | Gateway GM5472 PC Desktop
My video card stopped working. i changed the video
maybe it is your motherboard, reset bios ... because you can see anything do as it follows , unlupg power coard-open case - pull out little silver battery- wait 10 sec-put it back in- switch power cord and start your computer.. that will reset your bios. cmos more exactlly... if you see the boot menu it is ok.. but if you can go to os.. then you must set you bios video output to pci... try and write back
Feb 20, 2010 | Gateway GM5260 PC Desktop
Hp pavillion dv6000 no charge or power
I would say you have destroyed the battery charger. You can get someone with a digital mulitmeter to easily check if its charging or not.
Dec 03, 2009 | HP Pavilion dv6000z Notebook
Power coored got computor wood not come on unplug it all night
You should try looking inside the tip of the power coard. Alot of the tobisha notebook power coards break when they are unpluged and pluged back in check to see if there is a smal copper wire inside the tip of the charger. if it does not simpily replace the charger.
May 30, 2009 | Microsoft Xbox 360 Console
Hello my fan for the heat sink in my gateway laptop computer is not working
its eather got to much dust on it or something stoping it from moving
or the fan moter has simply gone bad you can eather take it apart yourself and fix it or bring it to a shop
but no matter what dont use the laptop till it works you will overheat the prosessor and the laptop will be useless
Mar 29, 2009 | Gateway M320X Notebook
My LCD monitor is going into power saving mode
The monitor doesn't receive the signal from the PC. It is either the PC not booting up or the VGA coard is faulty. Change the VGA coard. or try reseting the VGA cord.
Sep 30, 2008 | LG L1915S 19" LCD Monitor
My computer wont turn on. this problem happened last year and the problem was the power cable.
so have you tried a dipperent power coard again? What have you tried to identify what is the problem this time?
Aug 12, 2008 | Gateway Computers & Internet
Gateway GM5472 PC Desktop Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
