Question about Frigidaire Dishwashers
Brada portable dishwasher EP9242AWW
My dishwasher won't drain and gives me a error code E1. It runs it cycle but when it comes to taking the water out it just goes into error mode. Any Ideas? Please help.
    Problem Solver:
  • 19 Answers
Nice pic Barry, where did ya get it??
Posted on Apr 19, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
The pump is blocked or not working
Posted on Apr 13, 2014
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
SOURCE: Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Posted on Mar 22, 2010
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
SOURCE: Brada dishwasher EF2401 - water in bottom
I just moved in to a new house with brada dishwasher, everytime I used the water leeks from the bottom, can somebody help me to fix it, or do you think I should throw it away and get a new one.
Posted on Aug 08, 2010
Brada dishwasher EF2401 BS, error code E2, will not go to wash cycle it appears and starts beeping. There is no water sitting in the bottom. We have taken out the drain and Cleaned the filter basket
E2 - Abnormally long drain time. Check to make sure that the drain line is not obstructed or bent in a way that restricts water flow. Make sure the drain line is routed below the height of the dishwasher and that it has not been extended. This will inhibit the ability of the drain function to operate properly.
ref. https://support.edgestar.com/hc/en-us/articles/201075515-My-dishwasher-is-displaying-an-error-code-What-does-it-mean-
Dec 17, 2017 | Dishwashers
Where can I find replacement wheels for a brada portable dishwasher model EP9242AWW?
1. Google: "Brada Dishwasher Parts" and select one of several options
2. Amazon is also advertising appliance repair parts.
Pete
Sep 28, 2015 | Dishwashers
My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
Sep 25, 2015 | LG Dishwashers
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
How to fix a dishwasher that will not drain!
good to know the cleaning procedure worked for you. You can also get good results by using Finish dishwasher cleaning kit available from supermarket and running dishwasher empty with it once in 3-4 months. Keeps dishwasher clean and free of draining problems.
Apr 14, 2014 | Dishwashers
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Sep 05, 2008 | Dishwashers
Open Questions:
Dishwashers Logo
746 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
