Question about Garden
Tractor will not move in forward or reverse.
I have a yard machine with a hydro static trans.as I was cutting the grass it stopped moving in either direction. Where do I start to fix it????
  • 3 Answers
Check hyd pump drive belt
Posted on Jun 18, 2009
I have a model 600-699 1998 MTD 46in YARD MACHINE. Is it possible to check/add fluid to the trans axle?
I had a 1999 yard machine that did the same thing i had to replace the transmission it was still working when i sold it this year
Sep 04, 2017 | Mtd Garden
My craftsman yard tractor all of a sudden will not move, 42 " cut , 15.5.hp kohler motor Hydrostatic drive ,!
bypass rod pulled out to allow pushing the tractor, the noise is the hydrostat bypassing fluid (normal) if my crystal works
Apr 01, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
Massey Ferguson (simplicity) 2516 hydro tuff trac trans. Moves good for 1/2 hour then loses ability to move fwd or back at any speed. Eventually loses the ability to reverse completely but will move...
you have a problem in the hydro unit. probably a broken seal that is allowing oil under pressure to escape and build up temp in the unit Suggest you have a massey mechanic inspect and advise the exact cause as it will not be a one off problem
Jun 02, 2013 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND...
2 things, one, the belt jumped track, broke, or melted in place, 2, the hydrostatic ****** is out of oil, you didn't say if it was hydro or not. I doubt that the gear box has gone bad, but I would put more blame on a belt or pulley. Check it out. Hope this helps.
Mar 17, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman GT 3000 will not drive forward or reverse,belt seems ok
Is it a hydro drive or gears? If hydro the trans-axle is bad & needs to be replaced. It is an easy but expensive job.
Sep 30, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a cub cadet model 1420 with hydrostatic drive that will not go forward or reverse. The drive belt is moving and the hydrostatic unit was replaced 3 years ago. I still have to engage the lever to...
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Sep 28, 2010 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Lawntractor does not move forward or backward
you might check the pulleys to see if shear pin has broken.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Runs greeat but moves forward very slowly
Is this a gear drive or hydro ? If its hydro may need oil change and filter(tranmission) If not its most likely the belt.
Apr 11, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
176 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
