Question about Powersonic Power-Sonic - UPG UB1290 12V 9AH Sealed Lead Acid Battery F1 Terminal - 2 Pack - PS-1290MP212
How to charge 12v battery
How do you charge this battery
  • 3,904 Answers
Just hook these up to a car battery charger. If you need to buy one you can get these at Walmart, Target, CARQUEST, Sears, Napa and many other places similar.
Posted on Apr 14, 2014
Battery light stays on my John deer 737 starts good ?
check battery volts with engine off if battery volts on 12v battery ok... check battery running over 12v then battery is charging, stays on 12v battery is not charging ... replace alt. or gen which ever one you have... battery volts drops as running battery needs to be charged or replaced.
May 15, 2017 | Light Garden
I have shumacher se 82-6 battery charger and iam trying to charge my Chevy s-10 battery that is a interstate model mt-75 what setting do I put it in 6v 6a or 12v 2 a or 12v 6 a please help
12 volt 6 amps to quickly charge it from dead/flat or very low.
12 volt 2 amps as a trickle charge to maintain the battery when you are not using the vehicle for an extended time.
Nov 06, 2015 | Cars & Trucks
Can I recharge car battery with my stanley dps109 digital power station
charging voltage doesnt matter as much as charging current. what you need to know is that for a battery to charge properly it needs a feed of about 2.0amps over a period of 8-10hours (my recommendation) .
you need to establish whether your charger can provide a 12volt 2.0amp output.
take a look at this link, it very useful: Charging your car battery
Dec 11, 2014 | 2003 Toyota Corolla
How can i check a generator on a 67 shovel to see if it's charging properly?
Use a multimeter to measure battery voltage before and after starting. If 6V the battery voltage should rise to around 6.9V after starting, and if 12V the battery voltage should rise to around 13.8V after starting. If less than about 6.5V / 13V, the generator's not charging well enough. If less than about 6V / 12V, or if the battery voltage never rises at all, or frankly falls, after starting, then the generator's not charging at all.
Jul 23, 2014 | Cycle Electric Generator Dgv-2569 12v...
Why my SOL4UCN2 receives 18V but yields mere 12V for the charging?
Solar Panel Charge ControllerMCM Part 28 11138Velleman SA Part SOL4UCN2
This is a small charger mostly for small batteries and devices. It puts out max of 4 amps. What type of 12 v battery are you trying to charge?
Jun 07, 2014 | Velleman SA SOL4UCN2 Solar Panel Charge...
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
How to tell if battery is full charged before using it.
The easiest and best way to test any battery is with a volt-meter.
http://www.northerntool.com/shop/tools/product_12496_12496
The link above is for a multi-meter. These are inexpensive and are an extremely useful tool to have. For about $15-20 you can buy a meter which will test AC/DV voltage, resistance/continuity and often diodes and/or transistors as well.
A fully-charged 12v battery will give a reading of 12v (or very close to 12v) on a volt-meter when it is fully-charged. 6v batteries should read 6v, 1.5v batteries should read 1.5v, etc, etc.
If the reading is lower than the power output of the battery, the battery is either not fully-charged or one or more cells may be damaged. If cells are damaged, you will never get the full 12v output from a 12v battery.
There are other ways to test batteries but they are less accurate. It's possible to use a battery charger, but you can only use this to determine whether a battery is fully-charged if the battery is known to be good. A fully-charged battery should draw 0 amps on a battery charger, but a damaged battery may also draw 0 amps so this is not a good test.
Basically, I'd suggest you get yourself a multi-meter. You be glad you did!
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Mar 11, 2011 | 300 Amp Battery Jumper with Air Compressor...
Honda code P0A7F
I have a 2006 Honda Civic Hybrid and have had hell with it. I have also learnt much about it too.
One thing bad about the HCH2, is that the 12V battery controls the electronics, and the Hybrid battery charges the 12V battery. However the 12V battery is not charged all the time, and cannot be charged when the IMA is usually being used, and in different scenarios. (Buy a Electronic volt meter which plugs into the 12V adapter $14 Walmart))
It is possible that the 12V battery is being drained while driving and caused a voltage drop which can cause your problem. In your case, I would change the 12V battery anyway as they do not last long on Hybrids. (You may have to get Honda to trip the IMA warning lights.) In my case, changing the 12v battery helped the hybrid battery as it was the electronics reporting the charge level wrong.
Depending where you live, you will have a minimum 80,000 mile warranty on the hybrid battery.
Apr 14, 2010 | 2007 Honda Civic GX NGV Sedan
Charging
Negative partner, you can try all day everyday but 12 v is 12v and 18 v is much more. its just not gonna supply enough juice to charge the battery. the most youll ever charge it is 12 v... sorry.
May 02, 2009 | Ryobi Multi-Volt Battery Charger
Powersonic Power-Sonic - UPG UB1290 12V 9AH Sealed Lead Acid Battery F1 Terminal - 2 Pack - PS-1290MP212 Logo
116 people viewed this question
Top Powersonic Electronics - Others Experts
Are you a Powersonic Electronics - Other Expert? Answer questions, earn points and help others
