Question about Home
Belt diagram Need diagram showing belt and pulleys
  • Jerry Kramer
    Jerry Kramer Apr 14, 2014
    Hi Karen Conyers, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Need to know what you need a belt diagram for.
  • Karen Conyers Apr 14, 2014
    Allis Chalmers Ac130 lawn mower, the bracket that holds the front of the mower deck up is also disconnected
    Sergeant:
  • 192 Answers
No Problem.
Posted on Feb 20, 2015
1996 geo prizm 1.8 ltr lsi timing belt replacement diagram
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Feb 02, 2012 | 1996 Geo Prizm
I need to replace the serpentine belt on my car. How do I do that?
These instructions will help you . and also the picture below will help you more.
Locate the belt-routing diagram, printed on the fan shroud or possibly applied to the underside of the hood. This diagram shows you how to properly route the new belt, as well as identifying the location of the various pulleys, including the serpentine belt tensioner.
Move the belt tensioner off the Sable's belt using the serpentine belt tool. The tool connects to the side of the tensioner's arm and essentially acts as a handle for use in moving the tensioner. You can purchase a serpentine belt tool at most auto-part retailers.
Slip the belt away from the tensioner with your free hand and release the pressure on the tensioner with the tool. Pull the belt off the rest of the pulleys by hand and then remove it from the engine well.
Grab the old belt and new belt with one hand and put your foot through the other end of the belts. Stretch them both to their full length and check to ensure their both the same size. The old belt may have up to one-inch of extra length due to normal stretching that occurs during the belt's service life.
5
Wind the new belt, rib side to the pulley, around the crankshaft pulley. Consult the routing diagram and route the belt to the next pulley on the diagram. Continue to route and then check the diagram until you have the belt wound around every pulley except the belt tensioner pulley.
6
Double check to make sure the belt routes exactly as shown on the diagram and then move the tensioner aside once more so you can route the belt over the tensioner pulley as shown in the diagram. Move the tensioner back into place slowly and remove the tool.
Good luck
Jan 03, 2011 | 1996 Mercury Sable
Need to replace serpentine belt on 2006 Nissan Altima. what are steps?
the first thing to do it locate the under hood diagram that shows the belt route. if there isn't one than be sure to make note or make your own diagram of the belt position and how it "snakes" around the pulleys and in what order. the next thing you need to do is locate the tension pulley. once you know which pulley is the tensioner you place a wrench and socket on the bolt in the center of that pulley. and turn it counter clockwise as you do you should notice the belt getting some slack as this happens slip the belt off the most accessible pulley. after you get the belt off the pulley be careful not to pinch your wrench on anything.once the tensioner has been released pull the belt out from around the other pulleys and replace with the new on pulling it around all but the most accessible pulley at which point you can reapply tension to the tension pulley and pull the belt around the last pulley before releasing and putting full tension on the belt take a good look and be sure that the belt is on all of the pulleys correctly then let off and voila thats that hope this helps
Dec 24, 2010 | 2006 Nissan Altima
I need a belt routing diagram for a 2000 ford taurus 24v dohc engine. Know where I can find one on the web? (No sticker under the hood. And I was dumb enough not to pay attention when I took it off.)
OK, one doesn't need a belt routing diagram to reinstall a new belt.
Just route the belt so that one by one you put the ribbed part of the belt up against the ribbed pulleys, and the smooth part of hte belt up against the smooth pulleys. Do this until one arrives at the tensioner and release tension with a breaker bar to put the belt on the final tensioner pulley.
Check that the tensioner has enough spring load for the belt to maintain the right friction against all of the serpentine pulleys.
That's all there is to it.
Sep 09, 2010 | 2000 Ford Taurus
How to put serpentine on
heres a diagram to show you how the belt goes i also labeled where to loosen the belt with a rachet, this releases the tension so the belt can be removed.a194fc5.gif
Aug 09, 2010 | 1994 Oldsmobile Cutlass Supreme
2006 Nissan frontier 4 cylinder belt diagram + tensioner pulley
They are under the hood or on the front crossmember.
Regards,
matt
Sep 14, 2009 | 2006 Nissan Frontier
I need to replace a broken belt. There is a pulley mounted on a leaf spring. Does the belt go through this pulley?
This is the belt tensioner. The belt doesn't go around it -- the outside edge of the belt presses against it.
There is sometimes a diagram inside the dryer showing the belt routing -- if no diagram, it's just trial and error and can be very frustrating.
Charlie
Aug 23, 2009 | Dryers
Replace serpetine belt manual
normally there is a diagram on the shroud of the radiator
Aug 19, 2009 | 1998 Dodge Ram 1500 4WD
Serpintine belt installation?
when you lift the hood on your car and look on the panel by your radiator or the cover that covers the top of your radiator is there a diagram that shows the routing of your serpentine belt? Most all cars have this diagram in the place. It shows how the belt is routed. The only other thing you need to know to get the old belt off and another one on is look for a pulley that has spring loaded tension on it that is called a Idler pulley. There should be a square hole in the front of the bracket for this idler pulley that will accept a 3/8 or 1/2 ratchet or breaker bar. Put it in the square hole and then use pressure to push the pulley down so that your belt will easily slip off. If you go to a parts store they will show you how to take it off if you buy the belt from them and can' figure it out.
May 09, 2009 | 1998 Oldsmobile Achieva
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
