Question about Frigidaire GLHS36EESB Side by Side Refrigerator
Have a model glhs66ejwo refrigerator and the number 4 is flashing for the refrigerator side but freezer is working
Master_Tech
  • 770 Answers
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Posted on Feb 17, 2008
  • 9 Answers
SOURCE: REFRIGERATOR IS NOT GETTING COLD,FREEZER ICING UP
What you need to do is get a amp meter check the amp draw of the defrost timer. also check the defrost thermostat and ohm the defrost heater out.
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: I have a Frigidaire Model FRS6R5ESBF that is 3
Could be that the freezer is icing up stopping the air flow coming up into your fridge, try switching it off for at least 12 hours with the freezer door open.
Posted on Nov 02, 2010
heatman101
  • 43501 Answers
SOURCE: I have a side by
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 25, 2011
mc1bean
  • 3053 Answers
SOURCE: control panel number 4
Hello, There has been a couple times, Frigidaire was sending out the wrong control board in the correct box ( believe it or not it happened to me 2x ).. finally i had to call ELECTROLUX directly and had them send me the board direct to customer.. i believe that the 4 is because there is a wiring issue with one of the microswitches where the damper motor is and it will not allow the damper / control board to recognize "open" position ..I don't know how old your fridge, but in this case you should get a tech out with some testing equipment. Thanks Mike
Posted on Oct 23, 2011
Why does the fridge side of my fridgidare side by side keep flashing on 4
FFHS2622MB3 FRIGIDAIRE REFRIGERATOR Manual ...
www.searspartsdirect.com > Kitchen Appliance Parts > Frigidaire Parts
Download Manual for Model FFHS2622MB3 FRIGIDAIRE REFRIGERATOR. ... ShopFor Parts. Click a model number to find parts at Sears PartsDirect.
Jul 28, 2015 | Frigidaire Refrigerators
We have a 4 year old frigidaire side by side refrigerator, model phs69ejss0, it has stopped cooling fridge and freezer and there is a 4 flashing in refrigerator temp display area, any idea how to fix?
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Dec 09, 2012 | Frigidaire Pro PHS69EJSS Stainless Steel...
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
Frs6lc8fs3. freezer nor frige is working and flashes a #4 on the display.
On your model the digital controls are the main controls called a Genesis Control. It has 2 part numbers for the same part. 241739701 or 1196804 Digital Control
When compressor and fans are not running that control is the most likely reason. Reading #4 may be a failure code but looking over the wiring diagram there is really not much more that could be the reason for a fault failure code of that board. Shows that you still have voltage to the board but because everything is controlled from there like measuring the freezer and refrigerator temperatures, defrost and switching the compressor and fans off and on I believe your problem is there. Sorry about the troubles, Sea Breeze
Oct 15, 2009 | Frigidaire FRS23KF7AB Side by Side...
Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
I have a refrigarador model number: 4a72700444 and is not frizing no more is allmost new only 4 months, I am in honduras Central America, the problem that is flashing the number 4 and I dont now what to...
if its an electronic control model fridge and its flashing 4 in the freezer side then its detected a fault in the freezer side you need to call for service or contact the store you bought it from
Jan 15, 2008 | Refrigerators
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire GLHS36EESB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
