Question about Dryers
I have a whirlpool imperial series refrigerator
I have a whirlpool imperial series refrigerator what is the hose for in the photo I have provided
  • 3 Answers
Looks like water supply line(s) for an Ice maker or cold water distrbutor.
Posted on Apr 14, 2014
  • Brian Dalton Apr 14, 2014
    Do u know if I can get rid of all this extra hose will it mess any thing up cuz one end is hooked to pump roles into fridge then back out same hole to the front of fridge can I use a coupler and get rid of the roll
TheMobilian
  • 8220 Answers
SOURCE: dryer will not heat
Model number needed to look up fuse location or simply use Repairclinic.com to look up the fuse location yourself. These newer models have not been out long enough for a retired old dude like me to come across one. But I bet I could repair it.Since yours is this new you might want to get factory service to take a gander at it before you attempt a DIY to prevent voiding any warranty you may have left.
Posted on Jan 19, 2009
jsrock516
  • 5911 Answers
SOURCE: My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
It may not be the heating element causing your problem. There are other components that can fail that will cause the same symptoms. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. Please inlcude your complete model number (located on a nameplate around the door opening) when asking questions. I hope you find this information helpful.
Posted on Sep 07, 2009
Controlfrk
  • 304 Answers
SOURCE: Looking for the age of Whirlpool electric dryer
Link Below will give you the ability to calculate your manufacture date from the letters in the SERIAL number.
Whirlpool Date Codes
Posted on Sep 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Posted on Jan 03, 2010
  • 449 Answers
SOURCE: my whirlpool imperial series dryer wont heat
have the coil checked
Posted on Sep 14, 2010
How do I remove the agitator? ***** hose wrapped underneath.
The link is for a whirlpool and the agitator is very similar for most of the top loaders. the link is for a repair but in your case you will only remove, clear the trapped garments and re install.
Broken Agitator Whirlpool Imperial Series II
Jan 10, 2016 | Washing Machines
Why is my 2001 Whirlpool Imperial Series side by side refrigerator frosting up around the ice maker?
Ice makers can do this for several reasons. One is the incoming temp of the water is causing condensation to form and it freezes. Another reason is air leaks from the ice maker door.
Aug 22, 2014 | Refrigerators
I have whirlpool imperial series refrigerator model et1lfkxkq03, which has freezer on top. Water from freezer is leaking into refrigerator. I cleared out the freezer and can't find the clogged drain.
You will probably have to remove the back panel, which is the evaporator cover. The defrost water drain is always at the base of the coil. **** the drain out and pour some hot water down it
Jun 22, 2011 | Whirlpool Freezers
Water on interior shelf of refrigerator - Whirlpool, Imperial Series with top freezer
First check the door seal for leaks, If none found. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Apr 14, 2010 | Whirlpool Refrigerators
Whirlpool imperial series dryer heats not spinning
Jan 03, 2010 | Whirlpool Dryers
Whirlpool imperial series freezer not cold
my freezer is not getting cold enough but it still makes ice
Feb 08, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
Dryers Logo
54 people viewed this question
Top Dryers Experts
