Question about GE Ovens
GE Built In Wall oven JTP25SOH6SS wont completely shut off
Oven and touch pad all work great except when I finish cooking and press CLEAR/OFF I hear the beep, the temp LED goes off like normal, if an element was red it will go black, but the Oven and fan wont shut down. I can open the door and it will still run. I left it open for 10min and it waont shut down. I have to go hit the breaker. I will replace the temp sensor and see if it helps.
    Prodigy:
    An expert who has answered 500 questions.
  • GE Expert
  • 650 Answers
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Posted on May 25, 2014
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
Posted on Apr 01, 2009
SOURCE: Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Posted on Feb 06, 2010
  • 523 Answers
SOURCE: Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
Posted on May 27, 2010
My GE JKP45W double oven had and F1 code go off...we pressed clear and it stopped but now the oven wont work at all. The control pad still lets me press bake and choose a temp and then press bake...
Had similar issues with my GE oven. (same Model) Removed the oven control module and sent it to FixYourBoard.com. For $160 they repaired the board in about 1 week. Received it (my same board) and put it back in. The oven works great! Recommended. (No, don't work for that company, just a happy customer)
Sep 22, 2011 | Ovens
I have a JT955 GE Profile 30"double oven...when the food is cooked, and I press "clear/Off", the oven won't shut off...continues to maintain temperature? Tonight, I had to shut it off,...
Your wall oven has two main components that control the oven. The main control computer and the user interface. Your problem is probably in the user interface, although it could be the main control or both. I have had some success cleaning the ribbon that connects the user interface to the control with a little rubbing alcohol. That only works some of the time though. Due to the fact that the oven works except for the cancel button I would lean towards replacing the user interface if cleaning the ribbon dose not work.
Aug 29, 2011 | GE Profile JK955SFSS Electric Double Oven
The start button doesnt work, but all the rest do, What can it be?
Its a very common occurence for certain buttons to work on the touch pad yet others dont work.The only fix is to replace the touch pad.
Gene
Jul 30, 2011 | GE JKP30CMCC 27" Built-in Single Electric...
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Feb 28, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Bake button does not work.
if the buttons are the touch pads then your control has failed and you will have to replace it .mm
Jul 14, 2010 | Maytag 30 in. Electric Single Wall Oven...
May 27, 2010 | GE Profile JTP56 Electric Double Oven
I have a Kenmore oven with no directions. We cannot get the broiler to work. Can you tell us how to do turn it on? billiejack69@hotmail.com
Here's the manual for your oven, based on the model number you provided.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0522659.pdf
If this isn't your oven, use the following link to enter in your model number to get the correct manual, free.
http://www.managemyhome.com/mmh/ (click on the manual tab)
Hope you find this Very Helpful and best regards!
Here's how to use the broil function of your wall oven:
Press the BROIL pad. (This will
automatically set HI Broil).
lb. While the set indicator is flashing
in the display, press the BROIL
pad again if you prefer to use
Lo Broil. Use Lo Broil to cook
foods such as poultry or thick
cuts of meat thoroughly without
over-browning them.
2. Press the START pad.
3. When broiling is finished, press
the CLEAR/OFF pad.
Aug 28, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
F3 & F1 Errors & oven shuts off
Concerning the F3(Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Concerning the F1(Stuck touch pad)
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Jun 02, 2009 | GE Ovens
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
