Question about Kitchen Appliances - Others
Taylor 430-12 margarita machine flashes mix out light when full of liquid
I have a Taylor 430-12 margarita machine. I filled it with water to test it and it turns on in wash mode but when it is in auto mode the mix out light blinks on and it doenst turn on. I opened the panel in the back and if i press both switches in and hold them down it will turn on. But when released it shuts off
  • 139 Answers
SOURCE: Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Posted on Dec 02, 2007
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
Marrie
  • 563 Answers
SOURCE: Zanussi ZDT6252Non filling / rinse hold light flashing problem
Hi
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Apr 21, 2008
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
SOURCE: My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
Posted on Aug 05, 2010
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
I have a 2 hopper bunn ultra 2, both sides are icing over on the outside
the mix is too rich. add some water to each side. it freezes based on torque, not temp.
Aug 17, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Washer willl not fill. some very small amount of water drips into tub. i fixed the problem once by slowly adjusting the switch. it began to fast fill when the water level switch was between water level...
sounds like a bad / stuck mix valve --- the mix valve is the plastic part that the hot/cold hoses connect to on the back of the machine,, remove the two hoses..remove the back panel and the valve is held in place by one small screw,, label wires hot/cold and remove the valve. write down the make,model and serial number of th emachine and take the valve down to your local appliance repair shop and buy a new valve and then install into the machine --- hook everything back upp and test the machine,, all should be good -- with full water flow.
c...
Feb 04, 2011 | Kenmore Washing Machines
I plug in the 6 gallon air compressor and it starts filling up then i hear an air leak but can't determan where it is located at but the machine does nor shut off because it will never full to maximum...
Mix several tablespoon full of liquid dish soap with water and put it in a spray bottle, then squirt all the piping joints. If there is a leak you will see lots of bubles.
Dec 13, 2010 | Bosch Air Tools & Compressors
The left side of the machine is freezing, but it's pushing all of the frozen product to the top of the lid and overflowing
each side should only have 2 to 2 1/2 gallons of mix. there is a line on the bowl that is the max fill line. as it starts to freeze, the auger pushes the product to the front and up. if it's too full, it'll over flow. just empty some out.
Nov 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
I took apart a Taylor 430-12 Frozen Margarita machine and need help on trying to reassemble it...
Taylor 430, craziest issue. Liquid is not flowing in hopper all the way. It stops and starts bubbling at the top. Nothing is blocked, reassembled several times with/without face plate. The water will only go halfway in the hopper. No type of blockage. can someone offer any ideas, suggestions. Im lost
Oct 09, 2010 | Taylor Ice Cream Makers
My Hotpoint machine has filled with water and won't empty error F-05 FLASHING before that all lights were flashing ??
Error F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Jan 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Kitchen Appliances - Others Logo
50 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
