Question about LG LRSC26944TT 36" 25.5 Cu. Ft. Side-by-Side Refrigerator w/ Digital LCD Display & Jet Freezing Draw...
Water is (dirty) things are floating in the water. white "fakes" big and small
We have changed the filter and the water is still dirty. flakes are floating in the water.
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 650 Answers
This could be from sediment that forms on the inside of the tubing from the filter through the reservoir in the refrigerator and to the water dispenser. I had this happen a while back. I had to replace the tubing and water reservior. It solved the problem.
Posted on Apr 13, 2014
2 Suggested Answers
  • 30 Answers
SOURCE: i changes my water filter on an lg fridge now i
When you put in a new water filter on you should run the water for about 5 min.Hope this helps
Posted on Feb 21, 2011
I have a kitchenaid refrigerator (Model KSRS25ILBL02). The water from the dispenser has some tiny white flakes. I though it's the water reservoir (100' coil tubing) problem. But after I took the...
have you ever changed the water filter that's in the front bottom sticking through the kickplate?part number 4396508 and it's around 45 to 50 dollars
Apr 13, 2011 | KitchenAid KSCS25FKSS Side by Side...
Our Whirlpool Refrig GD25DFXFW02 is working fine our problem is the ice maker , the cubes contain white flakes, is there a coating on the ice maker that could be chipping off> We have changed the filter...
The inside coating has come off the inside of the ice maker . The white " flakes " is calcium deposits , sticking to the exposed cast metal , inside the ice maker , and sticking to the cubes , after water freezing in the mold . You need to replace the ice maker .
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Kenmore side by side refrigerator water dirty
You may need to replace the water reservoir located behind the crisper. They are known to flake and cause the problem you describe. They are usually replaced with a coil of water line instead of one larger reservoir to stop the problem.
Oct 11, 2009 | Refrigerators
The water from my new whirlpool has particles floating in it. I've already bled 2 bucketfuls of water.
What are the particles? Do you have a filter installed on the line to the fridge?
Take the line off going to the fridge (turn it off, should be valve nearby). Put end of line in a very clean bucket or gallon glass jug. Fill it. Any particles? Yes, the fridge water system is dirty. No, your house water system is dirty.
If it's your house, install a whole house water filter. If it's your fridge, call the store or the manufactureer and discuss it with them on what they are going to do to rectify it. Just make sure it's not your house system first!
Sep 20, 2009 | Refrigerators
Amana side by side
Undissolved minerals can appear when ice cubes are added to chilled drinking water. Freezing tap water causes dissolved minerals to solidify and scatter, giving a cloudy appearance. When ice cubes melt, any undissolved minerals settle to the bottom. These mineral compounds in our drinking water are naturally occurring and safe.
Sometimes we see black particles which can be the non-stick surface of the ice mold flaking off.
Sep 07, 2009 | Frigidaire FRS23R4A Side by Side...
Not making ice
replace complete im and water filter , 100 % it will work :)
Jun 26, 2009 | Amana Refrigerators
E15 water is draining but clothes still sodden,
The problem is your pump or filter is blocked.
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me plz……………………….
Mar 21, 2009 | Hotpoint Aquarius WD640 Front Load...
New Mr. Coffee Espresso machine producing white gunk
Hello aura20,
I bought one this week and had the same problem. I used vinegar and rinsed thoroughly and yet the whit flakes remained. I did some research and found that high end espresso makers often have very fine screens that catch minerals and grounds and so on. This Mister Coffee espresso maker has only a metal basket with tiny holes so it's not really filtering anything. Moreover the metal is treated aluminum, so it scales naturally. Also, if your water is hard like mine that just makes things worse. I just tore off a piece of paper towel only big enough to line the bottom of the filter basket and not come up around the edges. Then I put a drop of water on the paper towel and pressed the paper towel against the filter basket so I could see the little holes through the paper towel. Then I rinsed the machine again and the white flakes were completely gone from the water and the paper towel had collected it instead. I did the same thing with a new piece of paper towel and I added coffee, I did not add the maximum amount of coffee and I did not tamp the coffee. The product was smooth and creamy as it came out of the machine very slowly. But it tasted great and it was strong and clean. Upon removing the basket I found hard dry grounds stuck to the basket and paper towel. I had to use a spoon and running water to dig all of it out. It's not as good as professional espresso makers, but it'll do for a quick shot. I hope that helps.
Mar 04, 2009 | Mr. Coffee ECM20 Espresso Machine
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Water has debris floating in it
Sounds liek you have a hard water problem.  That debris is more than likey limescale and hard water build up.  A filter does not always remove it all.  You need to get a water softener.
Aug 10, 2008 | Jenn-Air 21.6 cu. ft. Side-By-Side...
LG LRSC26944TT 36" 25.5 Cu. Ft. Side-by-Side Refrigerator w/ Digital LCD Display & Jet Freezing Draw... Logo
111 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
