Question about Minka Aire Ceiling Fan
My Mink Aire fan "ticks" in the cooling direction, but doesn't in the reverse direction. Ticking stops immediately upon cutting off the power. What could cause this?
    Genius:
  • Minka Master
  • 1,617 Answers
Might be wobbeling a little. Try balancing the blades and see if that works.
Posted on Apr 14, 2014
Hi, I have two Como White Minkas, five bladed. One is in a room with a very high ceiling and required no balancing. It has lots of air above and around it to work with. My second one is in my kitchen with little room above or on one side of it (ceiling and soffit wall) and I have the same clicking sound. It clicks when the blade gets close to the soffit above the kitchen table (has less than a half inch of clearance). It only clicks on the second or third setting (medium and high) but not on low. I decided that is because there is some air compression on the side near the wall that imbalances the blade that is near the soffit wall as it spins. I tried balancing it but realized after a while that it was fruitless. That is because it is only out of 'balance' when it has to compress the air against the soffit wall but is fine when it gets past the wall. All balancing for that one point will achieve is putting it out of balance the rest of its circumference. But, the click is the blade(s) out of balance at that one point. And, by the way, balancing a blade requires the patience of a person watching curling. Start in one place on a blade and move it in (or out depending on where you start) and do this until you decide that is not that blade. Stir and repeat. I spent a day until I realized my location was causing the imbalance. Oh, I love my fans!! I had a bad receiver in the fan and had a replacement part in days. I have the radio wall switches as well as the remotes for both. If you have the remotes and the wireless wall switches you will find that one remote will operate both of them even when you only want one on. It takes trial and error to find how to stop this. Except every time my daughter uses it she messes up my strategy and turns the light on in the living room and it turns the light off in the kitchen. We ended up using the wall switch in the kitchen. But the tech is cool.
Posted on Apr 24, 2014
4 Suggested Answers
SOURCE: I have a Minka Aire
I have the same problem! Please post if you find a solution and I'll do the same.
Posted on Jul 26, 2011
  • 11800 Answers
SOURCE: I recently bought a house
The reversing in a single phase AC motor is done by switching the flow of current thru the starting coil. For that to happen both ends of the coil must be accessible on the outside of the motor.
Unfortunately the motor in this fan doesn't have that so there is no way to install a reverse switch on it without extensive modifications on the motor: it will have to be opened, the starting coil identified, the captive end unsoldered from the main connector to which it is attached and extracted outside. From there the ends will have to be soldered on a special relay and wiring that would have to be inserted besides the usual wiring of the fan. From there a special command wire will have to be sent to the remote receiver board that you would have to insert it there also. To put it simply: the labor (which must be done by a pro) would cost more than a new fan.
So if you need a fan with reverse then just buy one: it will be way easier, faster and cheaper than to retrofit this one.
Posted on Aug 19, 2011
SOURCE: Minka Aire Fan will not reverse.
My fan is a concept II and it had the same behavior. I called Minka Aire support about this - they said it was either the reverse module or the receiver. They sent me both no charge! I replaced them and now my fan reverses. i am not an electrician, but the replacement was fairly easy. Just made sure to disconnect 1 wire at a time, connect it to the new wire, etc until I was done. Minka Aire support said they would walk me through it on the phone but I didn't need them to.
Posted on Dec 10, 2012
My MGB fuel pump is always ticking, is this natural or should they cut off after its primed itself
On most MGB's they slow down and tick about every 4 seconds once the carb float chambers are full.
Feb 26, 2015 | Triumph tr250,tr6 fan belt mgbgtv8. fan...
Mr slim ticking noise
Open it and take a look, it could be debris or a loose wire.
Dec 06, 2013 | Mitsubishi Heating & Cooling
My computer starts and then automatically stops after a clicking or ticking sound all my power cables will work but nothing appears on the screen and my fan stops working?help me out please?
I m no expert but it sounds like you need a new motherboard or at least your PSU. I had a similar problem and used the opportunity to have my techo genius up grade the mother board and a fresh PSU and upgraded to windows7 and everything works like a dream and much more power!!!!!
Jan 15, 2012 | Intel Computers & Internet
Ticking sound under hood... Cooling fan spins both ways when the car is not running, is this okay? or should it only be able to be spun one direction? Serpentine belt looks fine! I'm told its a lifter, but...
Cooling fan is designed to freewheel below a certain temperature. Once that temp is reached it locks. In working that way, it saves fuel by not drawing power away from the engine unless needed.
Ticking can be a valve lifter. If it's minor, often some Marvel oil or lucas engine treatment will help with that.
Aug 26, 2010 | 2005 Jeep Liberty
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Ticking noise
HI, This is the result of a damaged Power control board. This board is not regulating the incoming current correctly. This board should be replaced, immediately. This will cause the in-house circuit breaker to blow. The board is located behind a access panel, on the rear of the unit. Have it replaced, soon.
It may be mounted on the compressor platform, as well.
Dec 22, 2009 | GE GDS20KBS Bottom Freezer Refrigerator
Ticking Sound
I just checked the HP site and it looks like it is indeed the cooling fan. The cooling fan is on the left-hand side with the vents under the left rear side. Check the screws, one or two may be loose. Also, something may have come loose on the inside so be prepared to open the entire thing and check for something that the fan blades are hitting.
Jan 27, 2009 | HP Compaq Presario CQ50-130US Notebook
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Minka Aire Ceiling Fan Logo
226 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
