Question about Frigidaire Pro PHS69EJSS Stainless Steel Side by Side Refrigerator
Refrigerator model glhs66ejw0 on the fridge side has a 4 flashing on the display]
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: We have a 4 year old frigidaire side by side refrigerator, model phs69ejss0, it has stopped cooling fridge and freezer and there is a 4 flashing in refrigerator temp display area, any idea how to fix?
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Posted on Dec 10, 2012
eric111375
SOURCE: Flashing #4 on temperature display
My fridge side does not work but the freezer does
Posted on Feb 17, 2013
Why does the fridge side of my fridgidare side by side keep flashing on 4
FFHS2622MB3 FRIGIDAIRE REFRIGERATOR Manual ...
www.searspartsdirect.com > Kitchen Appliance Parts > Frigidaire Parts
Download Manual for Model FFHS2622MB3 FRIGIDAIRE REFRIGERATOR. ... ShopFor Parts. Click a model number to find parts at Sears PartsDirect.
Jul 28, 2015 | Frigidaire Refrigerators
Frigidaire side,by side digital display flashing #4, what does,this mean....the freezer side is not warm, but nothing is staying frozen, the fridge side,is cool, but not cold
Good Morning Brett, thanks for your inquiry!
I understand that your Frigidaire refrigerator is flashing a "4" and you would like to know what that means. The "4" on your display means that there is a damper failure within your refrigerator and I would recommend checking the damper in the rear of the refrigerator to assure it is opening and closing. The damper is located in the back of your refrigerator. I would place your hand back there to assure it is blowing cold air into your refrigerator.
If the damper is not working it could be a potential issue with your damper, main control board, or wiring harness. I would then recommend performing a reset on your refrigerator. You can do that by unplugging the power cord for roughly ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Mar 31, 2015 | Frigidaire FRS3R5EMB Side by Side...
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Dec 09, 2012 | Frigidaire Pro PHS69EJSS Stainless Steel...
Can you tell me what a flashing # 4 means on the fresh food display,when I try to set temp.the flashing # 4 keeps coming back. the fridge temp. is too cold and freezes everything.
Hello Bryce,
I found a manual, although I cannot be sure it is for your exact model, it is located HERE. This is what is stated under "Temperature Adjustment"
IF TEMPERATURE DISPLAYS FLASH... If ever you see both temperature displays continously flashing, it may indicate that the control system has detected a performance problem. Call your service representative, who can interpret the flashing message. To maintain temperatures, a fan circulates air in the refrigerator and freezer compartments. For good circulation, do not block cold air vents with food items.
This is located under "Turning the Cooling System On and Off"
TURNING THE COOLING SYSTEM ON AND OFF You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and hold it for three seconds. Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops. To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds.
If the manual I selected is not the one for your particular machine, there are others located HERE. There are various ones only differing by a "upgrade" letter on the end, perhaps for different models of different manufacturers, produced by the same company.
I hope this is of some help
Joe
Sep 20, 2011 | Frigidaire FRS3R5EMB Side by Side...
Temp display (fresh food temp) has flashing # 4. Any idea's? Mod# GLHS36EFSB1 - side by side fridge
my Frigidaire showed the number 4 on the display after power outrage. And the temp is really warm inside. I unplug the power and plug it back 1 minute after. now I can set the temperature and it's working fine.
Mar 26, 2010 | Frigidaire GLHS36EESB Side by Side...
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
I am trying to turn the whirlpool space 4 american style fridge freezer on. the fridge seems to be fine, but the freezer side temp display is winking and the temp control is not responding and the warning...
You have a common fault with the electronics.
Check on a large auction site for a repair kit.
Item number: 330363841350
It will only cost £30, better then a few hundred.
Hope this helps
Sep 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge temp display flashing
Is the evap fan running? What is the current temp and how long has the unit been in operation
Dec 29, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Open Questions:
See all Frigidaire Pro PHS69EJSS Stainless Steel Side by Questions
Frigidaire Pro PHS69EJSS Stainless Steel Side by Side Refrigerator Logo
22 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
