Question about LG LFX28978
Ice maker quit dumping ice
Ice maker seems to try and dump ice, making sound and very slight rotating attempt, but doesn't rotate
2 Suggested Answers
  • 1891 Answers
SOURCE: ice maker doesn't make ice. It seems to not
this may be a bad heater in bottom of ice maker . if so replace the ice mker .. but do ck the tempts ..freezer must be 15 de or lower for ice maker to work properly .. hope this helps mm .. feed back pls ..
Posted on Jul 10, 2011
Ice Maker Failing to Eject Ice
icemaker not making ice video-
Nov 23, 2014 | GE Refrigerators
Whirlpool bottom freezer ice maker will only make ice if I pull and then replace the ice container, why?
The ice maker works off a timer that controls the discharge of ice, water fill, etc. Right before the tray discharges ice it is heated slightly so the ice is just slippery enough to discharge the ice. Unfortunately, now and then (for us) a chunk of ice remains in the tray. This chunk prevents the blades from rotating and eventually you have a mass of new ice with the blades in the wrong position. The blades have to be in a certain position for the heater to kick in. You are stuck with cracking up the ice stuck in the tray to get the blades to rotate again. We have an Electrolux ice maker but this problem occurs periodically. The root of the problem is it's failure to heat up the ice tray adequately to discharge ALL the ice. One thing to remember is that next time this happens you have to manually break up the ice in the tray and push the timer advance button until the 2 set of blades are fully closed (hidden) and at 90 degrees. From that point on at least the ice maker can start making more ice.
Aug 23, 2014 | Refrigerators
The ice maker is making a slight clicking noise and not dumping ice. why?
it sound as the tray should be look into. It can be worn out or crackrd
Jul 03, 2014 | Jenn-Air JCD2389G Side by Side...
Ice maker not dumping ice.
sounds like the icemaker timing or motor is bad. those parts are not replaceable on this model, you would need a new icemaker assembly
May 02, 2012 | Samsung Refrigerators
Ice maker doesn't make ice. It seems to not being able to rotate the ice tray to dump the ice.
Jul 10, 2011 | LG LMX28988
Ice maker seems to freeze up and will not dump the ice. If the ice maker is on, it makes a clicking noise like it is trying to rotate and dump the ice, but it does not happen. It is a Frigidare...
Good day,
Unsnap front plastic cover. There should be a white plastic gear in the center. Inspect closely. If a tooth is stripped out, replace.
Simple repair. One screw. Machine must be unplugged to remove. When re-installing there is a front and a back. Make sure the tongs on the gear are faced away from you.
The ice maker should be removed, and the ice dumped out while performing the repair to take the stress off the new gear.
If the above is not true, you will have to replace the icemaker.
Mar 01, 2010 | Refrigerators
Ice maker makes ice but will not rotate and dump the ice.
You have a thermostatically controlled heat release ice maker. Any number of issues can cause a failure to "dump" the ice. The harvest is started when the thermostat closes. A motor rotates the ejector fingers which are at rest in the 2 o'clock position. The ice maker operation will stall until the heater releases the ice from the mold. After the cubes are ejected into the ice bucket, the water valve will refill the mold with water to begin the next cycle. Lack of ice dispensing could be a failed thermostat, heater, motor or switch contact withing the ice maker module. You could simply replace the ice maker and save the expense of the service call.
Dec 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
The is a small heater in the boottom of your ice maker that is most likely not working. The heater comes on when the ice reaches a frozen state to allow the ice to melt just enough that the rotating arm can push the cubes out and into the tray.
Unfortunately, it will most likely cost more to have a technician fix the existing ice maker than it would to just have anew one installed.
I would opt for the new ice maker.
Jun 04, 2008 | Amana SXD524VW Side by Side Refrigerator
U-line 95 ice maker
This problem is due to the timer motor in the faceplate of the icemaker. Replace the faceplate part #150 and that should takecare of your problem
May 12, 2008 | U-Line Icemaker
LG LFX28978 Logo
22 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
