Question about Maytag PYE2300AY Electric Dryer
Fisher and paykel clothes dryer wont turn with clothes in it.
Dryer works when there isnt any cothes in it but won't turn around when there is clothes inside.
Works sometimes with one or two light items but will stop and start all the time,sometimes you have to manually spin barrel to get it started again.
Heater is working well just the problem with the barrell.
model is fisher and paykel 3.5kg number AD39.
  • 519 Answers
Hi
Most dryers work with a belt around the drum. Either the belt is stretched and needs replacement or there may be a belt tensioner which needs adjustment to tighten the belt.
What is happening in your case is that the belt is slipping on the drum as it is too loose.
Best wishes,
Graemevm
Posted on Jun 18, 2009
My dryer sounds like there are metal balls rolling around inside when clothes are drying
Sounds like the rollers are worn out. If they are fine then see if the dryer has glides on the drum.
Apr 23, 2014 | GE Profile Wizard DPSE592EAWW Electric...
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Dryer won't dry clothes
First check and see if your heating element is working by holding down the dryer door switch and turning on the dryer too see if you get a glowing from the rear inside of the drum. If it does glow then check to see if you have a kink in your dryer line or check to see if you have a clogged vent outside the vent to the dryer. Also you may want to try resetting your power to the dryer by unplugging the dryer and turning off and then backb on the breaker to the dryer then plug the dryer back in and see if that works.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
Nov 09, 2012 | Dryers
Whirlpool electric dryer
Hello there and welcome to Fixya :
This is a fairly common problem with these whirpool dryers.
I will provide you with the 7 most common things to look for
which contribute to the symptom Dryer won't stop are listed below. Check or test each item and watch any available videos. If you are still unable to solve the problem you may need to do additional research and troubleshooting.
Show all parts for model GEW9878LW0 For the symptom you selected, these are the most common parts or causes, ordered by the likelihood of fixing the symptom.
othercausesandconditions.jpg Air Flow Problem The most common problem when a dryer is slow is when the vent is clogged. If the dryer is slow, check the vent from the back of the dryer to the outside of the house. If that is clogged, clear it completely and test the dryer. If the dryer is slow after the vent is cleaned, clean the internal ductwork of the dryer. This will require some disassembly.
blower-wheel-694089-00918612.jpg Blower Wheel
Item # 686172
The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video $23.40 Quantity:
In Stock
heating-element-assembly-3401338--00621237.jpg Heating Element Assembly
Item # 528055
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity.
Part Testing Video $91.05 Quantity:
In Stock
lint-filter-349639--00685658.jpg Lint Filter
Item # 2659
Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
$38.95 Quantity:
In Stock
moisture-sensor-279366-00565298.jpg Moisture Sensor
Item # 469522
Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or coated with fabric softener. Clean the moisture sensor contacts inside the dryer and th
Oct 11, 2012 | Whirlpool GEW9878LW Electric Dryer
Tubmble dryer wont turn
Sounds like you have a bad idler and/or belt.
May 31, 2012 | Fisher and Paykel Dryers
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
My dryer will not shut down or advance when it is in the Automatic Perm. Press mode. Diagnosed with faulty timer, replaced yesterday for ~$300 and the dryer ran all night long. Is there a "dryness sensor"...
I have found that the permanent press cycle will continue to roll the clothes around on a rest and dry schedule until you take the clothes out and manually shut off the dryer. The idea seems to be to keep the clothes from wrinkling when sitting in a still dryer. I think that this is the way it was meant to work, but I am no expert, just another owner of a Fisher Paykel dryer.
Oct 15, 2010 | Fisher and Paykel DE06 Electric Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Articles of cothing get caught between the rotating drum and the frame--I'm sure these are not the correct structural terms. Too often, when I open the door, something will be caught and hanging, and I...
Your drum seal between the drum and the body of the dryer needs replacement, this is what causes the clothes to stick and tear holes in them.
I hope this helps
Please rate me
Aug 10, 2010 | Frigidaire Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
529 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
