Question about Janome 1600P-DB Mechanical Sewing Machine
How align the hook and the needle - Janome 1600P-DB Mechanical Sewing Machine
  • Janome Master
  • 1,388 Answers
HOW TO ADJUST my needle threader on my Pfaff Creative Visions 5.5 sewing machine
If the tiny hook on the needle threader misses the eye of the needle, it needs a careful adjustment to align it. I do mine by using a magnifying lamp to aid viewing the mechanism, then holding the needle threader down level with the eye, gently manipulate the hook until it is able to move into the eye., usually a tiny amount either side. If it needs adjustment vertically, then it needs the small screw carefully undoing a little, until the threader can be moved slightly up, or down.
Mar 19, 2017 | PfaFF Sewing Machines
How do I align the hook race once it has fallen out of alignmnet?
The first thing you will need to do is locate the screws that loosen the hook so that you can realign it. They are usually two Allen screws (may be 1 or 3, but typically 2) located just on the other side of the gear that drives the hook. Generally, you will have to remove the bottom to access the gear. Loosen, but do not remove those screws, just until you can move the hook by hand. Thread the needle, and lower the needle to its absolute lowest point; then with a measuring tape, bring the hook EXACTLY 1/2" away from the needle counterclockwise, and tighten one of the screws. Insert the bobbin case and bobbin and check to make sure that the top thread will catch the bottom thread. If it does, tighten both screws, and you're done.
Jun 23, 2014 | Singer 2250 Tradition
Skipping stitches on bobbin thread Juki DDL555-5. any suggestions?
sounds like u have the wrong needle or machine is out of time. if its a needle feed machine u might have the wrong bobbin case. try lowering the needle slightly. machine is easy to time. theres a mark on the needle bar which u align with the bottom of the bar guide then loosen the hook (3 screws) and move hook till it just starts to meet the needle. careful of side to side movment. bobbin case has to remain in the finger.
Mar 27, 2014 | Juki Sewing Machines
How to adjust the timing between the needle and the hook
theres a mark on the needle bar. when the mark is even with needle bar guide loosen 3 screws and align hook so it just a hair from the needle, watch you latteral distance too. i take if the feeder plate and one screw on feeder teath so i can see everything,. use short screwdirver to tighten on screw when i position. the tighten all 3 screws. turn hand wheel and ck timing and look at mark on bar. all this is assuming the needle bar had never been moved!!
Nov 16, 2012 | Juki DDL-8700
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
Will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Jul 04, 2009 | Janome 6019QC Mechanical Sewing Machine
Elna Diva 8000 -- Timing is off
if you want to open up and drill a littel hole to lock a gear in position then i can help you.
Jun 28, 2009 | Sewing Machines
Needle/Bobbin issues with Bernina Deco 600
Jim!
Perfect phrasing of the question, you have all the lingo/parts down pat!
First make sure your new needle is straight, then check to make sure it lines up in the center of the hole in the stitch plate.
There is basically a 1/2 sheet of papers (we use the fine waxy sticker backing paper as our guages don't fit well .1mm! ) distance between the hook and the needle.
Rotate your hook so that it is aligned with the needle in the center position, there should be 2mm between the top of the needle eye and the bottom edge of the hook.
Dec 29, 2008 | Bernina Bernette Deco 600
Threading & Use of Needle Threder
Threading as per image....make sure presser foot is up so top thread will properly engage in tension unit, make sure your thread is inserted in small guide on needle arm too. Your user guide should have a clear graphic of this process which is essentially the same for all machines.
As for the needle threader, once thru the last guide on the needle arm, raise needle to highest position, lower the needle threader so that the tiny hook engages the eye of the needle and place thread horizontally from L to R along the plastic arm so the tiny hook can grab thread, release threader and a small loop will form in needle, pull it clear and you are away !
If the tiny hook has been bent, a little judicious and gentle bending to re-align may be necessary, use a jewellers screwdriver or similar and please be very gentle
Feb 07, 2008 | Janome Jem Gold 660 Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
77 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
