Question about Sony VAIO VGC-V617G PC Desktop
How i conecct tv on sony vaio pcv 9960 - Sony VAIO VGC-V617G PC Desktop
McIndia
  • 131 Answers
SOURCE: sony vaio Pcv v300g tv tuner device failed to open
Install the Driver manually, the automatic installation of the driver is not installing the drivers properly, that is why when you restart the system it is not able to identify the device. for this uninstall the driver restart your system then install the driver manually.
Posted on Feb 12, 2008
  • 16 Answers
SOURCE: CD/DVD ENCLOSURE in Sony Vaio PCV RX860
http://esupport.sony.com/US/perl/tutorial-display.pl?tut_id=269&mdl=PCVRX860
this link is a tutorial of how to get the side panel off,
to get the cd drive out, you need to do a couple more steps.
first, you will need to take off the top and other side panels. this can be done by looking at the top back of the case. there are two clips that hold the top panel on. push up on the two clips and the top part will slide back and you can pull up on the panel and it should come off.
Next, you should be able to push some more clips on the top to get the side panel off. it should fold down just like the first side.
then, you need to take off the front two panels. the bottom part should be just a couple clips on the inside front of the case, and the top clips will be revealed when you take off the bottom part.
after that is done, you should be able to unscrew the cd/dvd drive from the case and unplug the cables connected to it from the top where you removed the top panel.
then you should be done
Posted on Jun 05, 2008
SOURCE: Sony vaio cpu is makes a lot of noise
im not 100% sure nut i think its the power supply cause some power supplys are very noisy and it might be why the cpu is overheating
Posted on Mar 31, 2009
Dr Geek MD
  • 201 Answers
SOURCE: how to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
Posted on Jun 02, 2009
  • 10 Answers
SOURCE: Noisy fan when downloading larger files
Well this really isn't much of a problem, as the fan turning on shows that it is doing its job. It turns on due to processor having to run faster, naturally raising its temperature, so the fan keeps the processors temperature within operable limits.
Posted on Jul 11, 2009
Been given a sony pcv9913 but no manual where do i get on
Been get a VAIO PCV-9913. But no manual and i cant watch TV troughtout TV Tuner. I can i solve it?
pauloladeira@hotmail.com
Apr 05, 2011 | Sony VAIO PCV-W20 PC Desktop
Dear all many many thanks for solving this probulm i have pcv 9960 computer on sony brand but i need for vedio, audio, network drivers if you solve my problum i shall be very thank...
Unfotunatelly there seems to be no Sony PCV 9960 computer model. Just check it out in case you made a mistake about the brand / model. Also clarify if it's a desktop or laptop.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 02, 2010 | Computers & Internet
Sony vaio tv tuner card and tuner card driver problem
You'll need to go to the sony website and download the MPEG encoder Driver. http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVV200G&upd_id=1415&os_id=7.
You might want to download the latest update drivers from this site also.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVV200G&LOC=3
Feb 14, 2008 | Sony VAIO PCV-V200G PC Desktop
Sony vaio Pcv v300g tv tuner device failed to open
Feb 12, 2008 | Sony VAIO PCV-V200G PC Desktop
Sony VAIO PCV-V100G PC
yes reinstall the tv tuner software.
there might be some other applications conflicting the same.
Feb 04, 2008 | Sony VAIO PCV-V200G PC Desktop
Sony VAIO VGC-V617G PC Desktop Logo
15 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
