Question about Amana Kitchen Ranges
My oven door is locked shut on an Amana AGR5630BDW. I keep getting F1 beeping error message. How can I unlock the door?
I've tried disconnecting all cables from back of sensor panel but no luck. Oven is only 3 months old!
    Sergeant:
  • 231 Answers
If oven is only 3 months old - call for warranty
Posted on Apr 13, 2014
fridgetech
  • 473 Answers
SOURCE: What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Posted on Oct 06, 2007
jyackle5
  • 8197 Answers
SOURCE: oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Posted on Dec 16, 2008
SOURCE: tried to selfclean my NEW oven but get error message F5E1
Reading all the questions and responses - I had the same problem (would press "self clean", it would run for less then a minute then give the error message), so once I saw the code was E5F1 and what it meant (thanks for whoever posted that), I just pressed on the door for the first minute of the cycle, and self-cleaning then worked. Go figure :)
Posted on May 01, 2009
techbuster
  • 5081 Answers
SOURCE: Amana oven AGDS902SS started beeping and showing a F1 error.
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC.
If you are an novice working over the control board. please do take the help of an authorised technician doing that.
Posted on Mar 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire, Gas Oven Door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Posted on Oct 01, 2010
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Apr 21, 2014 | Whirlpool Ovens
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Frigidaire Gallery Self Cleaning Oven
F1 code on frigidaire is bad EOC (clock) Try shutting breaker off 20-30mins see if it resets itself.
Jul 12, 2008 | Kitchen Ranges
Kenmore locked
The www.managemyhome.com website has some troubleshooting options when the door wont unlock. Good luck. Also you can download the whole manual online it you have your model number. Mine was inside the drawer under the oven.
Apr 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Amana oven
Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Oct 17, 2007 | Ovens
Kitchen Ranges Logo
73 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
