21rf vardaan Hai. Ihave a philiphs 21rfvardaan tv At beginning tv is on normal. the lot also funtion normal . After few seconds lot not function.it stop accilation the not in standby position(not glowing)
    Top Expert:
  • Televison & ... Master
  • 75,591 Answers
Check and replace its horizontal scan output transistor. If this transistor is leaky, this kind of fault can occur, due to overheating with time. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Apr 14, 2014
jack_daniels
  • 304 Answers
SOURCE: Zenith TV modelB25A74R picture rolls
can you please tell us what model maker of your TV unit..
Posted on May 07, 2008
  • 108 Answers
SOURCE: sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Posted on Jan 08, 2009
romsky79
  • 822 Answers
SOURCE: philips 21RF vardaan there is no sound but everything works fine
connect your av cables to av input of your tv then the other end again connect to dvd player av output. just simple.
Posted on May 27, 2009
  • 56 Answers
SOURCE: Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Posted on Jul 12, 2009
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
Why philips 21rf vardaan tv on for few seconds and turn off this problem remain same
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 16, 2014 | Philips Televison & Video
How to enter in server mode in 21rf vardaan crt tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
You should have its original remote control to enter the service mode. No universal remote control will go.
Aug 16, 2014 | Televison & Video
Philips 21rf vardaan lot fault
And when you hit it, it sometimes works?
Did you check the solder close to and on the HT transformer?
Please if you are not an electronic engineer, don't open the television, because voltages up to 25.000 volts are there. That can kill you.
Apr 13, 2014 | Philips Televison & Video
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Jul 10, 2009 | Philips 32PW6506 32" TV
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Jul 01, 2009 | Philips 32PW6506 32" TV
buy a remote for rs 100 . select the AV button on the remote .
May 27, 2009 | Philips 32PW6506 32" TV
Televison & Video Logo
Top Televison & Video Experts
