IBM wheelwriter 10 series ii 6783-001
Losing power at power supply, no blown fuse, caps, ect.. fast to power, with DVM connected I get 36V/5V and a few seconds no volts, bench testing does same thing, replaced KA3842 with new, same problem, tested power switch and cord, np found, tested bridge diods - good,I've tested all I could and all seems to be good, ? Maybe switching transformer, cannot test it. Need schematic of power supply if one has a copy to share, Power Supply P/N 1434518. The power seems to be draining down like a capacitor would when DVM is hooked into it.
    New Friend:
  • 28 Answers
Try to figure out any short circuit that causing power supply to come in safe mode , just give me more details about power supply , what kind of power supply is it?
Posted on Apr 13, 2014
Testimonial: "Lexmark Power Supply P/N 1434518 EC NO. 533136 Date Code 2/7/93 S/N B521456 It was built for Lexmark by Samsung. Input: 100-240 50-60Hz 2.0A OutPut: +34V DC 1.15A - +5V DC 2.2A From my Findings, all these parts are "OBSOLETE" Switching Transformer. Part# SC-9224 cannot be found or an equivalent, The "TYNO58", "L4960" out of circuit test show to be good. Finding a "SHORT" like this on "SMPS" is very difficult with out an schematic, to many parts to remove. Thanks for replying"
  • 2 more comments
  • saadat
    saadat Apr 14, 2014
    fault is expected not in power supply , its on next part where power is being used , power supply just switched off if load side is short etc
  • Mark Clinkscales
    Mark Clinkscales Apr 14, 2014
    Thanks saadat, I'll take your advice and look futher down the line, the power supply
  • Mark Clinkscales
    I have the same issue with power supply in chasis or out of chasis with 34/5 volt lines disconnected.
  • saadat
    saadat Apr 17, 2014
    try to remove dry soldering, may be it works do soldering on all major components , check diode soldering etc
  • 3594 Answers
SOURCE: Need owner's manual for IBM/Lexmark wheelwriter 30 series II
I can send you acopy of a ww30 manual for 25.00
DickyO
Posted on Mar 04, 2008
  • 3594 Answers
SOURCE: IBM Wheelwriter 30 Series II
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
Posted on May 16, 2008
  • 3594 Answers
SOURCE: IBM WheelWriter 30 Series II Operator Manual
The delay print and justify are both on the far rt. of the keyboard pressing these keys turns the features off and on. if this dosen't do it you're keyboard is bad.
DickyO
Posted on Aug 02, 2008
  • 3594 Answers
SOURCE: IBM Personal Wheelwriter 2
The cord you wrote about will work with no problem.
DickyO
Posted on Sep 13, 2008
  • 3594 Answers
SOURCE: IBM Selectric II correcting won't power up
Open the upper cover, remove the platen (roller) there is a latct on each side that has to be pressed down, after the platen is out thetre are two latches one on each dide just inside the the sides of the case pull them to the front, flip the margins inside and lift the case, give the motor a little push, if it starts get a can of WD40 and spray everything inside the T/W that moves.
DickyO
Posted on Oct 24, 2008
Ibm wheelwriter 6 Series II
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Apr 28, 2014 | IBM Lexmark Wheelwriter 6 Series II
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
IBM WheelWriter 10 Series II not functioning.
Could be many things. Take off the case and look for parer clips, staples or other debris on or under the PC board or in the power supply.
DickyO
Mar 05, 2009 | Lexmark Wheelwriter 10 Series II...
IBM Wheelwriter 10 Series II Typewriter
There is a plastic cap on the end of the print solenoid plunger whichis probably broken. They are available fron us for 15.00 including postage but can be a little tricky to install
DickyO
Dec 09, 2008 | Lexmark Wheelwriter 15 Series II...
Try a little light oil on the printer shaft. WD40 works well.
DickyO
May 13, 2008 | Lexmark Wheelwriter 10 Series II...
287 people viewed this question
k24674
jasbo
jasbo
