Question about Yamaha RX-V375
Yamaha Receiver won't turn on after USB plugin in. Help!
I plugged in my iPod into the USB port on my Yamaha RX-V375 receiver and now it wont turn on. Help!
    Genius:
  • Yamaha Master
  • 1,054 Answers
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
Posted on Apr 14, 2014
  • Bill Hybki
    Bill Hybki May 12, 2014
    Mine is a RX-V571 this worked thank you so much
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha Receiver RX-V463
Do not use HDMI thru your receiver. Go directly from the Cable box to the TV. Connect coaxial digital or optical to your receiver. Your receiver uses HDMI version 1.1 or 1.2, which is riddled with issues. If you want to read about them, Google HDMI Problems and you can read for hours. Long of the short of it is; Don't pass HDMI thru your receiver, use the receiver for audio only. Hope this answers the question. Sorry for the bad news! I'm in the industry and have been dealing with these issues for a couple years now.
Posted on Dec 16, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Posted on Dec 29, 2009
Testimonial: "great feedback. "
What does a Red X with a 6 underneath it mean?
Try soft reset by unplugging power cord on all components (tv, receiver, all source, router and modem) for a few minutes then reconnect.
Mar 27, 2016 | Yamaha RX-V375
How to reset yamaha rxv375 receiver won't turn on
hold the 'tone control' and 'info' buttons and press power. If the unit shuts back off immediately, then you have a problem that needs to go into a shop for repair.
Jun 23, 2014 | Yamaha RX-V375
Yamaha RX-V375 turns off during periods of heavy subwoofer/base sounds. Sometimes it turns itself back on, other times not. Help!
most likely you're hitting the clipping or the threshold of the power.
the other possibilities is you have a small short there.
one way is unhook our speakers, tidy the cable u and hook it back to make sure there are no shorts.
if this does not solve the problem then you just might be hitting the limit of your receiver which the only way is to change receiver or your speakers to match them
Oct 27, 2013 | Yamaha RX-V375
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
Receiver doesn't power up after the update.
Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
Oct 18, 2012 | Yamaha RX-V473 A/V Receiver Black
Yamaha rx-v2700 digital A/V receiver will not read 3trb external hard drive when it is formatted on nts and also tried with fat32 format and does not read mp3 files. when plugged into usb port the reciever...
Hi. Is the HDD drawing too much power from the receiver (does it have its own power supply)?
You could look at the troubleshooting guide in the user manual here:
Yamaha RX V2700
Feb 14, 2018 | Yamaha RX-V2700 Receiver
Ipod video onto TV through RX v365
No it is not. TV out requires special cables that can be purchased for the iPod.
Jan 12, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
YAMAHA YDS-11 TO A RX-V459
Hi, as per yamaha site RX-V459 doesn't have the DOCK connector which is used by YDS-11 dock (or the bluetooth module). This is the only possibility to connect the YDS-11. YDS nor receiver don't have USB connector and they are not needed.
For example RX-V465 does have DOCK connector and supports YDS-11.
For your receiver, you can use only analog audio cable with your iPod.
Dec 17, 2009 | Yamaha RX-V459 Receiver
Ipod connection to a Yamaha RX v363 receiver
Fortunately you are wrong :)
On yamaha site you can see that RX-V363 has a DOCK connector, which supports both iPod docking station YDS-11 and Bluetooth Wireless Audio Receiver YBA-10.
Jan 25, 2009 | Yamaha RX-V1800
Yamaha RX-V375 Logo
547 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
