Question about Coffee Makers & Espresso Machines
Lavazza blue descale
Stuck in descale mode
4 Suggested Answers
SOURCE: Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Posted on Feb 12, 2008
SOURCE: My Saeco Italia is stuck in the descaling mode.
I had this problem too. I was beside myself wondering what to do. I took the machine apart but there was nothing wrong. It was stuck in an infinite descale cycle. The 5 green buttons never blinked to say it was done. What finally fixed it was to close the steamer valve to where water was being being restricted from the steamer wand but still a little water was spurting out. It finally quit emitting water and the 5 lights blinked and the infinite descale cycle completed. This model espresso maker was a lemon and been nothing but problems.
jeff
Posted on Jun 05, 2010
SOURCE: Just need instructions to descale
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
Posted on Dec 27, 2010
My romeo nespresso wont leave the descaling mode
"DESCALING" is not a "mode." When the display says "DESCALING," it means that it needs descaling. Follow the directions in your instruction manual.
Jul 20, 2014 | Nespresso Romeo E350 Espresso Machine
My meile machine is stuck in the descaling mode
When you start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
May 23, 2014 | Miele CVA4070 Coffee Maker
Error code 11 lavazza blue
Lavazza LB 2210 error 82/84
Aug 20, 2013 | Lavazza 2210
My Incanto de luxe is stuck on descaling
Fill the container with a little water and turn on and wait until the tank is empty, then he goes to the wash, and you can finish the descaling
May 26, 2013 | Coffee Makers & Espresso Machines
What does descale mean?
It means that you need to clean out the lime scale built up in the boiled from the boiling water in the unit. There special scale removing solutions available commercially.
Jan 17, 2011 | Lavazza Espresso Point Capsule Machine
Descaled and rinsed the machine. now it is stuck in the rinsing mode. how do we get out of this cycle?
If you are rinsing after doing the descale it has to run out of water. The pump will quit and the rinse should be gone. The you have to go into the menu and select "reset descale" and chose "YES" and then "enter", then you can exit. It will tell you when it needs to be descaled again. Make sure that your water hardness is set to "4".
Dec 22, 2010 | Saeco Royal Professional Espresso Machine
I am considering buying a Lavazza LB2210 Espresso Machine. Owner says the screen says "fill with water" after she descaled the machine. What kind of cost am I looking at to get this fixed?
There is a floating plastic block in the water chamber that sits next to a sensor in the machine, that tells the machine whether the water reservoir is full or not. if its stuck, that could be the simplest fix ever. It could also be the sensor at fault, but it should be easy to test the float first
Sep 24, 2010 | Lavazza 2210
Just need instructions to descale my Lavazza Blue coffee machine
Sep 05, 2010 | Lavazza 2210
Coffee Makers & Espresso Machines Logo
46 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
