Question about Vehicle Parts & Accessories
Loss of horsepower on a 1995 jeep cherokee
Its not got much power its running off 4 cylanders i was wondering if it was the injectors or if it was somthing else i am pretty sure its the injectors
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
It can be a couple of things, Yes injectors is one, fouled or burned out spark plugs, bad plug wires to name off the most common problems
Posted on Apr 13, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Engine power problem
Yes, the open circuit can indeed cause your loss of power and the appearance of running rich.
Likely caused by replacing the exhaust manifold. Check wires to injectors.
May 22, 2015 | 1996 Jeep Grand Cherokee
2001 cherokee # 5 misfire..switched spart plug with another cylander still # 5 changed coil and injector didnt fix problem..HELP
Did you put a "noid" light on the injector connector to ensure it's getting the pulse to open? Do you know that you are getting spark at the plug? The HV could be leaking out of the cable or connector(s). Finally, if all that's good you may need to do a compression test.
Jan 03, 2015 | 2001 Jeep Cherokee
1995 jeep grand cherokee barley runs after warmed up?
fuel system problem; filter, pump, injectors.
Dec 13, 2009 | 1995 Jeep Grand Cherokee
Where are the bolts for the theromostate on a 95 jeep cherokee sport 6 cylander
Follow the top radiator hose to the thermostat housing, you should see two bolts, one on top, one on bottom.
Aug 26, 2009 | 1995 Jeep Cherokee
1995 jeep cherokee will loss power while driving
Most common cause of power loss is a stopped up catalytic converter. If you are saying it shuts off while driving, most common problem is the crankshaft sensor. IF you haven't changed the plugs or wires in the last 30K, it is definetly due for plugs wires, and probably cap and rotor button also.
Aug 14, 2009 | 1991 Jeep Cherokee Briarwood
Economy
Any vehicle that has to drive its own wheels requires horsepower. The more wheels that require power the more energy spent. If you only require 2 wheel drive to get you along that is good. Sometimes 4 wheel drive is needed. 4 wheel drive is needed in drastic situations. Does 2 wheel drive and 4 wheel drive differ? YES The power required to drive 4 wheels is increased 5.7% as to run 2 wheels. 4 wheel drive should be used at slow speed to overcome loss of traction of 2 wheel drive.
I hope this helps Moe
Apr 24, 2009 | 2006 Jeep Grand Cherokee
Is there a feul shut off in the gas line? or anywhere?
i had the same problem with my 96 jeep...apparently my ground wire for my pump had come disconnected, i used a little clamp to reattach it and havent had any problems out of it since...mite wanna try this before taking it into any shops
Dec 18, 2008 | 1995 Jeep Grand Cherokee
1995 jeep grand cherokee power loss
could be engine mounts have to replace mine engine almost jumps outta the compartment
Sep 18, 2008 | 1995 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
27 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
