Question about Acer Aspire Computers & Internet
Only certain keys work on my acer aspire 5736z-4790. I have to attach a wireless keyboard to type.
Only certain keys will respond
    Problem Solver:
  • 12 Answers
Unfortunate but truthful Fact: acer computers have the worst manufacturing practices/cust. service etc., they use old outdated parts from other major manufacturers, that's why their garbage is almost always cheaper than most other brands. Even their highest priced models, will fail in one or many areas just before or after the "warranty" is up, then they'll just stall and wear you out until you give up, sound familiar by any chance? Did you ever try to get help from them? Anyway, Do the keys go down and or click when you try to type? Or does it feel like there is something blocking them from underneath, in other words so they are able travel down then back up quickly and smoothly in their housing when you press on them. You'd be amazed what gets inside and under the keys on a keyboard. Try to blow some compressed air to loosen any particles or foreign matter that might have snuck in there. You can carefully and gingerly snap the keys off, but use an online guide on how to do it, just research it... The inspect and access what you see and go from there. OR you can also carefully and gingerly hold it with the keyboard facing down, and run your hand across the keyboard back and forth quickly to loosen any thing that might have gotten under the keys, and I have personally done this with my keyboard im typing on right now while I had my vacuum running over the keys (compressed air works too, I use a small compressor) instead of my hand, and it eventually loosened up, then sucked up the foreign objects that were blocking my keys. It doesn't take much to clog up the movement.
Posted on Apr 13, 2014
SOURCE: Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Posted on Oct 21, 2007
SOURCE: acer keyboard messing up
Fantastic! I was just having the same problem when I read this article and pressed FN+NumLk(F11), then the keys started to work properly again.
Posted on Feb 07, 2008
parrotheadpc
  • 2600 Answers
SOURCE: how to replace a acer aspire 5735 keyboard
Here is the factory service guide that explains complete servicing of the laptop. Make sure to save a copy for yourself, the file is free to use.
http://tim.id.au/laptops/acer/aspire%205735%205735z%205335.pdf
Posted on Oct 11, 2009
carloadrian
  • 571 Answers
SOURCE: windows xp drivers for acer
Thank you for using fixya.
There are no available drivers for windows xp for this laptop in the website of acer. However, I have found a site where you can download drivers for your laptop. Just check it out.
Click on the link below:
http://drp.su/drivers/notebooks/?v=Acer&m=Aspire%205736Z&id=8607&l=en
I hope this helps.
Thanks
Posted on Feb 03, 2011
Salim Baig
  • 283 Answers
SOURCE: how to take out hard drive from Acer Aspire 5736Z
salim_baig_2.jpg access the rear cover to for replacement of the HDD.
Posted on Jul 14, 2011
Testimonial: "thank so much.was not sure as i took out screws plate would not lift did not want to break it."
Hdmi doesnt work
You sure it's not that you just haven't switched over to getting the screen to display on your external monitor, not just on the laptop? It's usually done by pressing the Fn key (bottom-left on keyboard), and a function key (eg F5/F6).
Oct 19, 2012 | Acer Aspire AS5736Z-4790 15.6" HD...
Acer aspire 5736z-4460 won't turn on
tried to remove the battery and then re attached, turn on the pc laptop check if it works.
Aug 03, 2012 | Acer Aspire 5736z 4460 Laptop
Certain keys such as the "N" key and some others
Yes, a can of compressed air may solve it. Usually for me I need to remove the trouble keys and soak them in soapy water, dry them, and put them back on the keyboard. Be careful when popping them off as you can break them and have to order a new keyboard.
Please leave good feedback! :) Thank you!
Jul 29, 2011 | Acer Computers & Internet
Keyboard issues
Press the "Number lock" key.
Apr 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
MY ACER LAPTOP ASPIRE 4710 IS LAGGING + CERTAIN
could be the keyboard needs replacing,but try the driver 1st
Nov 18, 2009 | Acer 91.63X07.001 Keyboard
Aspire 5410 connectivity problem
this could be because you have accidentally turned off your wireless...
there will either be a switch on the outside edge of the laptop case which you can use to switch it back on
OR
if you look at your keyboard, there maybe a "wireless" type icon on one of the "F" keys... if there is and its a certain coloor press it at the same time as the "fn" key on the keyboard...
some laptops have a physical button and some laptops have a button the keyboard that switches the wireless off
good luck and please rate this answer if it has helped
trev
Aug 17, 2009 | Acer Aspire 6930-6771 Laptop
Acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
Dec 06, 2008 | Computers & Internet
Key board not responding
Try attaching an external keyboard to a USB port on the computer. If it works.
The keyboard cable is probably loose.
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
