Question about Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Cooker makes popping noise when off
The unit makes a loud popping noise when off. Like A gas build up but no smell of gas at all
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
It\'s possible you have a slow leak through one of the rail cocks ( gas taps) lift off the top and spray lightly some soapy water on the end of each of the rail cocks if it bubbles you have found the leak.
Posted on May 08, 2014
I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is loud...
Hi Loretta:
I'd contact the installer. This sounds as if there may be a slow leak. When the gas concentration is high enough it will ignite which would be the bang that you hear. The popping sound could be the flame at the leak source point re-igniting for a few times.
DEFINITELY CONTACT YOUR INSTALLER OR GAS INSPECTOR. THIS IS A SAFETY HAZARD.
Mar 11, 2015 | Dryers
My stove heater is making a loud popping noise when it cools
if you are vented into a chimney with out a liner this can cause noise to occur because vent gases are slowed down because of vent build ups more heat into exchanger. If you can not change vent lower gas pressure.
Dec 31, 2013 | Cozy Enclosed Front Console Heater 70,000...
Popping sounds thru mufflers/smell of fuel
Run the fault codes and replace faulty units as it sounds as if you have an over fuelling problem.
Apr 06, 2013 | 1999 Chevrolet Suburban
We have just bought a brand new 480cd gas rayburn boiler/cooker and it is making a very loud constant whistling noise. When the cooker part only is on there is no noise but just when boiler is going
This can be caused by several things. Incorrect Gas to Air mixture in the burner air intake valve. . Debris in the gas line to the boiler. To high a gas pressure. Depending on whether you installed this unit or not, will determine if you should try to repair or troubleshoot these issues. If it was professionally installed call the company that installed it. The only one you can't troubleshoot is the gas pressure. That needs to be done by a certified gas technician.
Hope this helps steer you in the right direction to solving the problem.
Mar 15, 2011 | Heating & Cooling
There is a strong smell of gas from my cooker, pipe from cyclinder to cooker appears ok , new world 55wlg
Do not light anything if you are smelling gas. Make up a soapy solution in a spray bottle and apply to all connections and look for bubbles. Most common place to leak is hook-up at cylinder and hook-up at cooker. If you can't find the leak and continue to smell gas, do not use it. Also make sure your cylinder is not empty.
May 15, 2010 | New World 55WLg Gas Kitchen Range
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
93 MX6 throttle body is Popping, loud,sounds like a diesel
Sounds like the pipe/connection from the exhaust manifold to the EGR valve that is located at or near the throttle body has a leak. That would make a loud popping noise.
Jul 15, 2009 | Maybach 62 Cars & Trucks
On one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
May 18, 2009 | Sylvania Televison & Video
Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
89 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
paulcarew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
