Question about Balance CM2015 15" LCD Monitor
Random shutdown about every 45min to 1hr monitor turns itself off - unplug for a minute or so and replug and monitor comes back on.
  • Balance Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 13, 2014
System Initializing
Have you tried unplugging the monitor from the 120 volt supply for a minute or two then replug and turn on. Like computers and some flat panel TVs they can freeze-up after an unplanned power loss and need rebooting
Jan 12, 2014 | Samsung SMT-190 19" Flat Panel TFT LCD...
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
Xbox360 console randomly shutsdown
take front face plate off and disconnect the wire for power and eject sensors. you will have to use the controller for ejecting a disk and powering on but quick fix and has no problems. i had to do it to mine and its still disconnected for 2 years now and now problems and no shutdowns by itself.
Oct 07, 2012 | Microsoft Xbox 360 Console
My monitor had been working fine, but recently when the computer comes up, it is on for a few minutes and you can use it normally, but then it will turn itself off. You turn the monitor off and back on,...
Try changing the cables first and see if this will fix it, if not, im sorry to say, but you need to replace the monitor. If your monitor is still covered by the warranty, you can call dell techsupport so they could replace it. Hope this helps
Dec 14, 2009 | Computers & Internet
MK241H sometimes doesn't turn on
Unplug the monitor from CPU Keep the monitor alone and see any problem. If not try to plug to some laptop and check again. We want to sort out the problem from monitor or CPU..
Dec 12, 2008 | ASUS MK241H Monitor
Dell SP2208WFP Flat Panel Monitor goes straight to power save mode
If the monitor is not turning blue that means it isn't picking up on the signal that is coming to it.
Pushing the power button on the monitor should make the monitor work and give you a no signal note if it isn't getting signal.
If it won't power on with its own power button you maybe having a low voltage problem in the monitor itself which isn't giving it enough to fire up after it has been sitting.
Just a note these monitors use and make power even when they are off, unless they are unplugged.
I'm thinking along this route also because when you said you unplugged it for a while that it did turn back on.
Only way to verify it, is to double check the monitor on another computer. and if it is the same then it will have to come apart.
Power issues are very common in lcd monitors, Lots of heat in a confined space. The bigger they get the hotter they get.
You would think they would have incorporated internal fans in these by now. But then they wouldn't sell as many !!!
bammbammfran
Search and you shall find me !!
Oct 14, 2008 | Computers & Internet
Does not turn on until you unplug cord, and replug in
its protecting ... the system just detected some other problems 2 ur system or power supply.. modern television has an auto shutdown protector circuit... i just said whwt i know... tnx
Jul 19, 2008 | Sony KP-53V80 53" Rear Projection...
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Feb 04, 2008 | Philips FW930R Shelf System
Balance CM2015 15" LCD Monitor Logo
53 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
