Question about Treadmill Doctor Lifestyler Expanse 850 Treadmill Rear Roller
Lifestyle 850 treadmill stuck in high speed
How do we fix
The incline on our Precor c964i is stuck in a high position (approx. 10% incline). Other than being on a high incline, the treadmill seems to be working fine.
Hi There,
Precor uses a pair of Triacs to drive the lift up and down. These triacs live on the lower board but are driven by the upper console commands via a serial link between the upper and lower. Most precor lift issues we see are related to the lower board but with Precor it could be an upper board or the CPU Chip that resides on the lower board or a failed Triac. Good Luck
Apr 07, 2017 | Precor Exercise & Fitness
Can not calibrate a true 850 ztx treadmill. has error code E5:sensor. aborts calibration saying no speed sensor. is the speed sensor located within the main motor? What lights should be seen on the...
However reset the treadmill
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 24, 2013 | True 850 ZTX-P Treadmill - Serviced
Horizon omega treadmill speed
Run the software calibration for easy diagnostic and fix it.
Go under the HOOD cover motor, and follow the steps.
God bless you
Sep 30, 2013 | Exercise & Fitness
Life fitness 95t speeds up after confirming slower speed in cool down mode, and also pauses after touching increase button on screen. both issues are dangerous
book an engineer, sound like motor controller, loose belt could also be a issue, needs a safety check where are you based ?
Jan 27, 2013 | Life Fitness Exercise & Fitness
Treadmill is stuck in fastest position and will not change
1) LUBe the elevation motor, in shaft and gear
2) adjust the small POTentiomenter for to liberate the elevation motor
3) clean the relais contacts, and tight every connector.
see the diagram and fix it.
Jan 18, 2013 | Proform 860 Competitor Treadmill
Lifestyle treadmill error
LUBE the deck belt,this happens because the lack of maintenance
2) LUBE the rollers bearing too, very important.
3) adjust the speed sensor see the diagram attached, clean it, and tight the plug.
4) adjus the REED swtich, see the diagram clean it, and plug the connect very well.
5) Try after you did the adjustment RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Oct 07, 2012 | Life Fitness Exercise & Fitness
Stuck on high speed
Run the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
Apr 23, 2012 | Bowflex Treadclimber
Ifit treadmill stuck on highest incline
RUN inmedaitely the software calibration for diagnose, troubleshooting and fix it. Now that machine is running in slow speed.
sincerly. God bless you
Apr 23, 2012 | Proform 740cs/745cs Treadmill Walking Belt...
When I put the key in, the treadmill belt goes really fast. Its like its stuck and I can't turn it down the knob keeps popping off. Do I need to get it serviced.
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run at high speed without setting any value or witout pressing the start button. You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i ahve added the picture of IGBT for your refference
ok
Sep 04, 2011 | Weslo Cadence CT 4.8 Treadmill
Client run on treadmill then suddenly its stop and display an error speed, then 5 seconds treadmill belt moves again and moves faster whats the problem of that?
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Feb 25, 2011 | Life Fitness 9100 Next Generation...
Treadmill Doctor Lifestyler Expanse 850 Treadmill Rear Roller Logo
27 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
