I want to make the line input on the back panel output a different sound
I want to skype with my headphones pluged into the line-in (blue) and mic pluged into the mic(pink) connectors on the back panel and still play music or movies out through the line-out (green) port on the back panel i dont care if the headphones dont play the same sound as the speakers as i only want to play music through my speakers. i have looked everywhere and everyone is giving a different solution none of which is what i want to do
    Sergeant:
  • 231 Answers
Check this link to the skype solution - as for the output, that should be configured at the sound card
https://support.skype.com/en/faq/FA11017/how-do-i-configure-skype-to-work-with-a-new-headset-microphone-or-speakers
Posted on Apr 13, 2014
  • 300 Answers
SOURCE: where do i connect the front panel MIC connectors in the motherboard
1 2
3 4
5 6
7 8
9 10
Pins 5 and 6 , 6 is ground.
Posted on Aug 26, 2008
cinek79
  • 320 Answers
hi check this web
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01357135&lc=en&cc=us&product=3644705&dlc=en
Posted on Aug 29, 2008
  • 998 Answers
SOURCE: need picture of dell dimension 8200 back panel
Here is a link to Dimension 8200 Front view and Back view: http://support.dell.com/support/edocs/systems/dim8200/tour.htm#1101572
The speaker jack is Green.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Posted on Dec 22, 2008
byteguy
  • 2229 Answers
SOURCE: front panel connectors/jacks is not working
OK--usually what you will find from the front is 3 connectors.
One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
The pin configuration on the motherboard looks like this ::::.
The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
Hope this helps.
Posted on May 14, 2009
heavymetal77
  • 721 Answers
SOURCE: Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Posted on Jul 16, 2009
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
I want to use this for skype on my computer and it wont pick up the mic
Hi hilldest,
These headphones cannot be used for your computer ,because you computer requires seperate input for mic, unlike the mobile phone where you have only one pin and then it includes the mic function with it.
So if you want to use the mic you can use it by connecting a seperate mic in the pink slot of your computer and you can still use these headphone to listen to the incoming voice by pluggin it in the green slot of audio output.
Hope this helps ..:) Your feedback would be appreciated.
Aug 28, 2011 | Sony DREX12iP Headphones
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Where to plug in external speakers on back panel I HAVE IT PLUGED IN TO THE BLUE INPUT WHERE THERE IS A BLK YLW RED GRN AND BLU THE CONNECTOR IS BLUE AND NO SOUND
Green is sound output
Blue is sound input
Black is for rear channels
Pink is for a Mic
Yellow is typically for a digital input/alternative for optical
Oct 26, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Roland MV 8800 No inputs, phono
Hi, post on mvnation.com, they will be able to help.
Jan 26, 2009 | Roland Mv8800 Production Studio
Headset
You use headsets to have conversations over the internet .. or to have a personalised audio equipment,.
You should have used the mic to start with, as you heard over the speaker your voice,
There are two pins. One for MIc and other for the headphones.
Use mic only when recording. other times keep it muted in control panel-> sound and audio...
you can use headphone for hearing when you don want the audio stream to be on speakers., TO use so, you have to take of the output from the CPU to the headphone pin after removing the speaker pin or configuring the audio controls control panel-> sound effect manager to have sound always in both theh speakers and headphones.
This requires you to have an appropriate configuration so that all 3 pins are aptly placed fot output from the CPU.
Hope you got what you asked for!
Apr 12, 2008 | Labtec C-322 Headset
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
