Question about Lowrance GPS
Lorance gps temp calibration
Water temp reading is about 15 degrees to low. How to calibrate for accurate temp reading
SOURCE: Screen Calibration problem with SteetPilot c330
Turn off the unit. Then hold down the power button for about 1 minute and the calibration screen will eventually come up.
Posted on Oct 13, 2008
r321567499
  • 74 Answers
SOURCE: inaccurate reading
I'm not sure why you need it calibrated if your Docotor says it's accurate but here is a web site link....
I hope this helps.
http://www.omronhealthcare.com/product/s1-1126-186-manual-monitor
Posted on Dec 25, 2008
  • 7 Answers
SOURCE: touch screen won't calibrate on garmin 2720 gps
The touch screen is a 4 wire resistive type made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches or cuts that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. You could send it to Garmin for a flat $250, but that makes no sense at all.
If you get another screen (Garmin won't sell you one), Here's how to replace it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon from the ZIF connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the two by the IR receiver.
When you reassemble, don't get frustrated with the gaskets, they're tricky but it can be done. Tom
Posted on Jan 24, 2009
kachbibi1
  • 979 Answers
SOURCE: Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Posted on Feb 15, 2009
  • 23 Answers
SOURCE: Viking DED0530TSS oven calibration?
With a small screw driver and a steady hand. Set the knob to the temp u want then pull knob off. Inside the stem there is a little screw. Try and regulate it slowly also allow it enough time to reach the desired temp. Good luck.
Posted on Sep 18, 2009
Our Danby 38 bottle wine cooler..
No that is not an option, use an accurate thermometer and verify the temperature, it may well be just an erroneous reading.
Apr 13, 2017 | Danby Heating & Cooling
The humidistat changes with home but reads about 20% low. Can the read out be adjusted to more accurately reflect the actual conditions?
A common problem is dirt. Dirt can affect the thermostat's calibrationand interfere with its operation. For example, if a thermostat is set to heat for 70 degrees is really maintaining a temperature of 73 degrees, the additional energy use can increase your fuel bill by as much as 7 percent.
Google your make and model #manual, the manual will let you knw if it can be calibrated.
Thermostat Temperature Calibration DoItYourself com
Jan 21, 2016 | Heating & Cooling
Outside temp is 5 degrees too low.
Check manual for calibration
Nov 12, 2014 | Ovens
My heater is heating to 100 degrees as indicated on the heater, but the actual temp in the spa is much less, usually 10- 15 degrees less
Press menu, scroll to settings. There should be a choice labeled "calibrate". You can change the temp reading here.
Mar 27, 2011 | Pentair Easy Touch Indoor Control Panel...
Compass reading on GPS 60cSx about 30 degrees too high
Calibrate the compass (Main menu --> Setup --> Calibration --> Compass), follow the instructions on the screen.
Also, see page 50 of the manual.
Calibration must be done outside - stay clear of any large metallic object (e.g. car).
Mar 11, 2010 | Garmin GPSMAP 60CSx GPS Receiver
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
Rinnai 1004 heats to a temp 4 degrees higher than set temp, adjustment?
You can adjust the position of the room air sensor found on the back of the unit between the heater and the wall. It is a black rubber bulb with yellow wires. There is a few inches of extra wire you can extend higher to get a more accurate reading of room air. While you are back there, check for drafts that will give you false readings.
Sep 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
GPS Logo
22 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
