Question about Maytag Bravos MTW6600T Top Load Washer
How to turn off spray rinse on maytag bravo xl washer
Turned it on for 1 cycle, now it won't turn off
  • 3 Answers
SOURCE: maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Posted on Apr 13, 2008
TheMobilian
  • 8220 Answers
SOURCE: maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 19, 2008
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
SOURCE: Maytag washer shutting off on rinse cycle
check the inline filter on the cold water inlet on the back of the machine
Posted on Jan 03, 2010
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
I have an issue that is rather strange! On the NORMAL cycle only, at the end when it should turn off, a rinse comes on and wets the clothes. The extra rinse is NOT on, the belt and motor are fine. I know...
Always supply a model number, each model has it's own foibles. It is very hard to assist without full details.
BUT, is this an "LAT" series Maytag washer??
If so, this is a normal rinse, the manufacturer calls it a "Spray Rinse" and it is quite normal.it only adds the water during the spin cycle, after the rinse water is ejected and then only for about 1 minute, the water passing through the fabric as it passes by the water inlet flume and empties during the spin.
Jun 12, 2017 | Maytag MVWC6ESWW Washer
I have Maytag Bravos washer, which displays an HC code at the end of the wash cycle. However, it has been working fine for months, and the hoses are in the correct places. What should I do?
Apparently your hoses are switched, it means you rinse cycle is pumping in hot water instead of cold. Turn off the water to the washer, switch hoes connections to washer or the wall, not both. This should fix the problem..
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 15, 2011 | Maytag Bravos MVWB400V Washer
My washer is making a ratteling sound a few time in the rinse and spin cycle, and when i turn to the clean cycle i put affresh in it and its estimated time is 1:02 mins but it only takes about 5 mins...
Ya gotta be careful about over adding detergent. But the rattling to me sounds like the basket is having trouble engaging. That might be due to a small item of clothing between baskets. This will more often than not display a F-72. Bravos service manual
Mar 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
