Question about Nintendo 64 Console
Doom 64 Issue
My Doom 64 game display is especially dark even on full brightness. Other games don't have this issue.
  • noneofyourbuisiness Jul 05, 2014
    Is both the game and the television on full brightness?
  • Nintendo Master
  • 429 Answers
Try cleaning the game pack out with qutips and rubbing alcohol to see if it makes a difference. It might just be a fact that these are older games and are out of date. I hade a problem with excite bike 2000 it would freeze and glitch up and not show all of the words when I put it on pause. When I had cleaned it out it was fine. It could be that then.
Posted on Nov 15, 2016
  • 6 Answers
SOURCE: Nintendo 64 Gameshark boots up with 1 game
after you load up 007 you must go to key codes to select your game. Then you turn it off and put that game in. It wont start again if you put the wrong game in so dont screw up. Then you can select cheat codes.
Posted on Jul 05, 2008
  • 26 Answers
SOURCE: Can't play wii games
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide......................................
Posted on Apr 07, 2009
  • 5 Answers
SOURCE: DS won't read game
make sure that the carteidge is clean, and the cavity inside the DS is clean as well...you can do this by putting isopropyl alcohol on a qtip...make sure you let it dry before powering on your DS again.
Posted on Jul 24, 2009
  • 20 Answers
SOURCE: my Nintendo DS Lite will only power on in GBA mode
make sure there is no games in the slot, then see if you can get around using the directional buttons and the a button. if you can get to the settings menu, go to the calibrate screen option. if you cannot calibrate the screen, (if the target moves but you cannot finish the calibration) then you probably have a bad screen. here is a website that can sell you ds lite parts. they are not cheap, so buy what you need, and only what you need.
http://www.nintendorepairs.com/parts/index.html
Posted on Jan 11, 2010
SOURCE: When playing Lego Harry Potter for the Wii the
It is a game issue fortunately. I thought there was something wrong with my Wii as well, but after reading tons of forum posts across the internet on many sites from people with the exact same problem, even with new consoles, the answer was clear.
This game has freezing problems for all versions, not just Wii. Unfortunately, I'm pretty sure the Wii can't download patches for its games, unlike the 360, PC, and PS3, So I have no idea how they are gonna solve this problem. Maybe recall the game and re-issue it?
Anyways, If other games work fine, your Wii is alright. If other games do not work all the time, or also freeze up on you, get a Wii Lens Cleaning Kit. I got one off of Amazon.com for super cheap (around 10 bucks), and it works like a dream, my console ran like new again. Hope this helps others who are concerned about this issue.
Buy Wii Lens Cleaning Kit on Amazon.com
Posted on Sep 25, 2010
My nintendo 64 cuts out part way through a game
This is an old system, so there are several possible issues.
Some games require a memory expansion pack. You can usually find this on the Internet. It'll increase your RAM levels-essentially, a new RAM chip. To simplify a bit, that's short-term memory. If your game is skipping and losing audio before your console crashes, this is a likely problem.
Your game itself could be the issue. To clean its data contact points, put your mouth near it and suck air in. This removes dust from inside. Now, if it still doesn't work, get some nail polish remover and a Q-tip, and scrub at blackish-colored spots until they fade away a bit. (This solution works with GameBoy/DS as well.)
Your console is outdated. It was released in the 90's; it's possible that it's just falling because it's old, especially if children played a little rough with it. It's frustrating, especially since your warranty is definitely void and Nintendo can't replace your console, but sometimes these things happen.
Apr 21, 2014 | Nintendo 64 Console
Why cant i increase brightness in video games!?
It depends on the video game, in the menu, graphics section, some have a brightness adjustment. That said, your computer will optimize the game settings for best performance at start. So it may be the limitations of the computer? You may be able to adjust brightness but may suffer in a slower game? It all depends on the game and your computer specs.
Dec 15, 2012 | Computers & Internet
Purchased Doom II, Ultimate Doom and Final Doom, but switched to new computer with Windows 7. Now these programs don't work.
The only thing you can try is the "Compatibility Mode" option in windows 7. Right click the executable for your game and choose properties. Go to compatibility tab and choose a lower version of Operating System (e.g. Windows XP SP2) that supports your game. Save the changes you made by clicking on OK and try the game again. If this won't work, there is no other way but to use another computer with a compatible OS or downgrade your OS to a lower version that works.
You might also want to check your game manufacturer website for any update or patch that you can use to make the game compatible for Windows 7.
Hope this helps.
Jul 30, 2011 | Computers & Internet
Hi, i have bought a new acer aspire 4738g.the laptop is great,light and very powerful.everything is okay but,in my 14 inch display contrast changes even in the slightest displacement of the...
This is an issue with all windows based computers. It is quite normal. you have 2 options: Get a desktop with a flatscreen lcd monitor or buy a mac. Mac laptops have the crispest clearest screen I have seen so far on any laptop.
Mar 25, 2011 | Acer Aspire 4730-4947 Notebook
Nintendo 64 controller pak doesnt save games.
Well it sounds like that they are bad memory cards then. I had a problem with my memory cards for perfect dark saying that they are corrupted attempt to fix so I had cleaned out the memory cards and the part in the controller that they connect into and where find after they were cleaned out with qutips and rubbing alcohol. It could be the same issue that I had or they are just old or bad memory cards. The worst case could be the console or controllers could be having issues.
Dec 23, 2009 | Nintendo 64 Console
DOOM won't run in Vista ...what can I do also Duke, Hexen, etc.
Are you certain your DOOM game is compatible with your Vista Operating System? Vista comes in 32 bit and 64 bit versions. Software compatibility depends on the game being designed for the specific OS you have. If you're running 64 bit Vista, I'm guessing your game is designed for Windows XP or 32 bit Vista.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
Wierd color issue
hello! it would be good if you will inform the company wherein you had puirchase that gadget right away. there might be some technical problem with it. companies always provide a warranty, you consult it to them right away..thanks! feel free to contact me for more inquiry.
Apr 10, 2009 | Acer X193W LCD Monitor
Moniter screen turns dark green on switch on ,why this happens?
it could be an issue with your graphics card, is this a recent issue or a gaming problem?
does it happen all the time?
if always dark you could check your brightness settings etc, or get the backlight checked by a technician.
if the backlight has gone, you will see the screen fine if you shine a torch onto it.
Feb 25, 2009 | LG Flatron F700P 17" CRT Monitor
Nintendo DS lite power light comes on but both screens stay dark?
When you boot the Nintendo DS you can change the illumination settings in the main menu.
One the main menu, you will find a sunny symbol in the lower left corner of the screen. Click on that and you should be able to change the level of illumination. If you are also wondering if you can change the brightness during game play, you can't. Games such as Mario 64 DS come with support for brightness change but otherwise you have to do it before game play.
Sep 20, 2008 | Nintendo DS Lite Console
LCD Monitor went Dark
hi bear2243055
I suggest reinstalling your graphics device drivers and maybe the game as well.
May 08, 2008 | Samsung SyncMaster 931B 19" LCD Monitor
Nintendo 64 Console Logo
60 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
