Question about PfaFF Quilt & Craft Pro 7530
Pfaff sewing machine bobbin thread keeps breaking
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
SOURCE: Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
Posted on Jun 15, 2008
  • 323 Answers
SOURCE: My pfaff synchromatic 1209 machine--the
You machine has a screw that fits the end of the shaft and the head pof the screw has broken. You can buy a new screw from a sewing machine dealer but if the whole assembly has come off you may need to take it to a dealer to have it reassembled properly. There is a spring inside which is very difficult to install.
sewman7
Posted on Aug 22, 2008
  • 30 Answers
SOURCE: Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Posted on Jan 24, 2009
  • 255 Answers
SOURCE: Pfaff 260 bobbin thread not picking up
Hi. This can be terribly frustrating, but the most likely cause for the bobbin thread not catching is that the needle is inserted wrong. There is a flat side on the shank of every needle and that has to be facing a specific way on your machine or the needle's grooves can't make the stitch. On most modern machines, it's my experience that the flat side goes to the rear, facing away from the operator, but some of my older machines need the flat side facing to the left or to the right.
Another thing that can cause the bobbin thread not to pick up is a bent needle, but in my experience it's usually the needle not in correctly.
(Cost me $85.00 to find this out!)
Let me know if this works, ok?
Happy Sewing!
Robbie
Posted on Apr 01, 2010
I just bought a Pfaff 7570 New needle, new thread ut the bobbin thread is still breaking after about 2 inches of stitching
put the bobbin in the bobbin carrier correctly so that the thread unwinds in the right direction
Sep 18, 2017 | PfaFF Sewing Machines
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
Top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Mar 09, 2014 | PfaFF Sewing Machines
Pfaff 1200 top thread keeps breaking
Sep 03, 2013 | PfaFF Sewing Machines
My thread keeps breaking every time I start sewing on my pfaff 4.0 sewing machine. O have changed the thread two times. re threaded the needle six times and ensured the needle was in the correct location....
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
Thread keeps breaking
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
We just got a pfaff 138 and put T-90 industrial thread but it keep breaking the thread. i cant figure out why, it seems to be threaded correctly. any thoughts?
You may have a different weight thread in your bobbin and your need may be wrong for your project. Check your manual or call Pfaff.
Sep 19, 2010 | PfaFF Sewing Machines
PFAFF hobbymatic 935 bottom-thread keeps breaking. It worked before but now it's not working
The Pfaff hobbymatic 935 was a mid to late 80's production machine (proudly made in West Germany, LOL) and was a transition between the older "oil me or I die" style of machine and the more modern "maintenance free" machines. Only one part of the machine needs to be oiled from time to time, the track around the bobbin. One drop of oil should keep her from snagging and breaking. If that doesn't do it for you try a newer bobbin thread as old thread can become weak sitting on the bobbin.
Hope this helps!
May 02, 2009 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
