Question about Ctm Health & Beauty
Can you help me try to figure out why my scooter will not move forward or backward? It is fully charged and the horn works.
  • 2,059 Answers
I would get the batteries checked for power. Just because your charger shows fully charged quite often the batteries are low but enough power for lights or horn which does not take much power. i suspect bad batteries.
Posted on May 05, 2016
  • 39 Answers
SOURCE: Have Zoom 220 HMV 3 wheel scooter. Charged battery
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Posted on Jun 23, 2009
  • 313 Answers
SOURCE: Batteries are fully charged with the lights in
Remove the seat and the plastic cover over the batteries. look at the lights in the cover or at the back of the scooter an see if they are plugged in. It is a common fault of when working on the scooter to forget to plug the lights back in on assembly. Hope thats what it is.
Posted on Aug 12, 2010
  • 11800 Answers
SOURCE: it is completely charges (electric
I'm supposing that you haven't disengaged the brake with the handle on the rear, next to the right wheel - it should be in the up position.
If this is the case then i'm sorry to tell you but this is a bad defect that you cannot fix yourself: the controller board has failed and the motor is no longer powered, locking the wheels. You will have to contact the ones that sold it to you, they will have to completely replace it. Unfortunately there is only a one year warranty on it so you will have to pay for it - around $500.
Posted on Mar 12, 2011
  • 692 Answers
SOURCE: Hello, my scooter is fully
outback you will have to get a new speed pot and replace the old one. Contact the provider where you got your scooter to see if they will fix it for you Hope this helps
Posted on Apr 16, 2011
  • 4 Answers
SOURCE: Strider mobility scooter shows fully charged but
may sound silly, but have you checked that it's not in freewheel mode, as this would prevent the motor engaging
Posted on Aug 25, 2011
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Hello, my scooter is fully charged, all the lights and horn are working. But it will not move forward or backward. The small green light flashes 7 times and stops for a while before flashing again. The...
Apr 16, 2011 | Health & Beauty
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or...
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Oct 03, 2010 | Electric Mobility Mobility Electric Power...
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
I would say the throttle pot is slightly out of neutral allowing the scooter to travel slightly when turned on. Try moving the throttle lever slightly in the opposite direction to which the scooter is travelling (i.e. if the scooter moves forward when turned on, press the lever to go backwards, but only a small amount). If the scooter stops and you hear a clicking noise from the back of the scooter (this would be the brake clicking on) then that would be your problem. Would just need a small adjustment but best left to a dealer as it has to be sopt on! Sometimes scooters will not work if the throttle is slightly out but if its only a very small amount out of neutral, it might sometimes work in the manner you have suggested. We have come accross this fault on a few occasions. Hope this helps...
Mar 07, 2010 | Health & Beauty
Scooter won't move forward or backward
go to electricscooterparts.com get a rear wheel clutch assemly fixed ours!!
Jul 25, 2009 | Cycling
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Oct 29, 2008 | Pride Sonic 3 Wheel Portable Scooter
Health & Beauty Logo
126 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Dan Apthorp
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
