Question about Wahl Cordless Pet Clipper Kit Pro-series Includes Case
Wahl clippers: I have the cordless model. Can not get blade to stay on. pops off the minute I turn clippers on.
Clipper has detachable blade which will not remain in place once I try to clip. Pops off.
  • Wahl Master
  • 1,248 Answers
Bend the 2 spring clips at the front of the clipper down a bit and try again.
Posted on Apr 20, 2014
  • Rhoda
    Rhoda Mar 22, 2015
    when you say bend them down what exactly do you mean?
  • Ross Keen Mar 22, 2015
    Bend then downwards a little bit, down is away from the lid with the writing on. It's hard for me to guess what your problem is but that is a solution I have employed many times when the catches are not holding the blade firmly.
I am recently purchased wahl professional 1124 hair clipper in usa it is is very hard sound. How to less sound
make sure that the clipper blades are properly fitted
they will stand off the clipper body until they line up with the movement
turn on the clippers and gently press down on the blades to ensure full engagement
Apr 25, 2016 | Wahl Health & Beauty
Blade won't snap back on
make sure the clipper is running when you try to snap the blade on.
Dec 08, 2015 | Wahl 8786451A Arco SE Pet Clipper
Balde keeps popping off. how do I adjust..exactly?
The blade should have 3 locating 'lugs' 2 either side and 1 at the rear if any of these are broken then its a blade problem and you will have to buy a new blade.
Mar 22, 2015 | Wahl Adjustable Chromado Cord/Cordless Pet...
I have the Wahl cordless clipper and the blade head keeps on coming off.It is not damages any ideas/
Is the little lug at the bottom of the black plastic blade chassis missing? If not check the 2 'arms' that the spring clips lock over, arms are on the blade chassis. If that is all OK you will need to see if the clips need adjusting (bending)
Jan 16, 2013 | Wahl Animal/pet/dog Clipper Cordless Arco...
WAHL model MC. Very loud (mechanical) buzz when on. May be clipper blade out-of-adjustment (?) Do not have instruction manual on how to adjust.
Should have a flat head screwdriver handy... on the side of the clipper there is a dial where you can insert the tip of the flat head.. Turn on the clippers and turn that knob with the screwdriver slowly till it hums nice and even..
Nov 15, 2010 | Wahl Health & Beauty
I lost my instruction manual. How do you oil the Wahl beard and mustache trimmer model 99180? Thanks, DJ.
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
Jan 24, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
Have lost charger and battery number for model number9918 please help
from the picture you have here, That I see you have a Wahl 8554 Wahl Alpha cordless clipper. but you stated the model 9918-6171 Groomsman Beard and Mustache Trimmer model, You need to be sure of what model you have. He are the two picture of each model. if this is correct, Mannys Sharpening has the charger for this cordless clipper, I had the same problem and he sent me one it took about 2 weeks for delivery.
27a92b7.jpgThe clipper on your Left is Wahl 9918
3283d36.jpg This clipper is the Wahl Alpa 8554 cordless
Call Mannys Sharpening he has all the replacement charger for Wahl.
323 263-4697
Jul 28, 2009 | Wahl 8554 Hair Trimmer
Reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Sep 03, 2008 | Wahl 9765-301
Wahl Cordless Pet Clipper Kit Pro-series Includes Case Logo
159 people viewed this question
Top Wahl Pets - Others Experts
Anglia Clipper...
Ross Keen
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Wahl Pets - Other Expert? Answer questions, earn points and help others
