Question about Boston Acoustics Recepter Clock Radio
Recepter Radio HD does not work
Recepter Radio HD does not play FM stations it previously played well. Or, plays once in a while, for just 5 to 10 minutes. OK for AUX input, i.e., as speaker for Netflix etc.
2 Suggested Answers
  • 23 Answers
SOURCE: Boston Acoustic BA735 wont play on my computer
The cable with 2 rings is stereo, a single ring is mono, you have to make sure that you are using the right cable/speaker combo. The speaker output is usually lime green, hope this helps, more info perhaps?
Posted on Jan 24, 2009
My radio has recently started to go into seek mode on it's own and I can't stop it when it starts.
New HD Radio Applications Seek to Fix System Flaws ...
diymedia.net/new-hd-radio-applications-seek-to-fix-system.../7560
Jun 22, 2015 - ... Asia, and elsewhere: instead of every station having its owntransmission ... Nautel is bringing the same concept to FM-HD as part of its "HD ... Ismy radio broken? ... Inovonics expects to go into full-production mode on the Justin 808 in ... As it has been for the entirety of HD Radio's history, I guess it'll be ...
Troubleshoot problems with radio stations in Windows ...
windows.microsoft.com/.../troubleshoot-problems-wi...
Microsoft WindowsLearn about solving problems with trying to play FM radio stations in Windows Media Center. ... Why doesn't my FM radio play? FM radio may not play for one of ...
Feb 08, 2016 | Cars & Trucks
How to get the dvd player to play threw my truck speakers?
if you dvd play came with a wireless fm modulator read the owner manual and set up the fm station to get it to work . if it does not have a built in fm modulator you need to buy one.
the pull out your radio and run power to the fm modulator and then connect the factory anntenna to one side of modulator and the other side goes back to your factory antenna location at radio . then set the fm station you set for the fm modulator run a set of rca cables from the fm modulator to the dvd flip screen and it should work . i would think your flip screen dvd play would have a built in fm modulator that is wireless .
caraudioquestion@gmail.com
Oct 28, 2010 | Insignia Mobile DVD Player with 9.5"...
Ipod will play on tunebase fm but it won't charge it
There are issues with newer ipods not being 100%compatible with all devices. It is done intentionally by Apple to maximize their profits. For example, an FM transmitter charges and plays on one Ipod, but then a newer ipod will play with the FM transmitter, but the ipod display shows that it is incompatible and will not charge. Same issues with a docking station and a radio. All worked with three other ipods, but the newer ones either won't work or charge depending on the device. Even though ipods play with certain devices they may not charge them and vice versa. Thank Apple for that. I hope this helps and good luck!
Feb 02, 2010 | Audiovox Jensen Universal iPod Docking...
Cannot play ipod in 99 daewoo lanos
instead of pressing the left/right scanning buttons hold them and then let go when you want to stop
Aug 15, 2009 | Daewoo Lanos 1999 Car Radio/stereo...
Factory radio recieves am stations only no fm stereo
get a new one as they are cheap these days!
& not worth the labour costs to try & fix them anymore!
Cheers Rob
Jul 20, 2009 | 2002 Chrysler Town & Country
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
Itouch does not play through fm transmitter
i had the same problem... like it played through the itouch speakers and not through the radio how do i get it to play through the radio
Apr 07, 2009 | Griffin Technology iTrip Auto FM...
Radio won't play
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
Feb 01, 2009 | SanDisk Sansa Clip MP3 Player
FM-stations
I figured it out!! YAY!!!!
so here is how you set the presets:
- click source until you are on the FM radio
- click down or the play/pause button... this shows the presets
- pick which present you want to set your station on by going right or left
- press and hold down or play/pause button until preset number starts flashing
- once flashing, use right and left arrows to select your station (if you wait too long it will stop flashing and you will have to start again)
- once you have gotten to your station, push down or the play/pause button one more time, and it should be set!!
hope this helps, good luck!!
christy*
Aug 02, 2008 | JVC RA-P11 Portable Audio System - Made...
Boston Acoustics Recepter Clock Radio Logo
88 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
