Question about Karcher 1750 psi Electric Pressure Washer
Motor runs but not alot of pressure - Karcher 1750 psi Electric Pressure Washer
    Guru:
  • 145 Answers
Make sure you re-leave any stored water pressure before performing a repair! (UNPLUG THE HYDRO OR DISCONNECT THE SPARK PLUG) SAFETY FIRST Valve 200344GS Order now for same day shipping 365 day return policy... If you can find these parts within the pump body they are probably being held open by calcification debris. http://www.simoniz.ca/en/images/support_buttons/general_pw_troubleshooting.pdf
Posted on Apr 16, 2014
I have a 2002 gmc sierra 5.3 it runs rough Boggs down when I accelerate. The scanner says map/(baro) barometric pressure sensor circuit low imput , random/multiple misfire, evaporative emission control...
If it has alot of miles try spraying the underhood area with the engine running with carborator cleaner..If the engine revs up its a vacum leak. These little leaks will toss a modern engine into full @^@#^@$ mode. Find the leak then try it..I've seen leaks cost alot of money because of misdiagnosis through OBD2 readings.
Dec 20, 2013 | 2002 - 2002 GMC Sierra 2500 Barometric...
91 f250 runs fine cold but dies when warmed up
How long since a tune-up? Any applicable trouble codes? If temp related check the coolant temp sensor. Sometimes ford calls it a cylinder head temp sensor. I'd also use a gage and check proper fuel pressure.
Sep 15, 2017 | 1991 Ford F250
My 1993 ls 400 lexus,dont get power when i press the gas. when in park,the motor runs really rough and i smell gas, And before this happen,whenever i would take gas top of to put gas in,a lot of pressure...
The two are unrelated. First the no power is the catalytic converter, it is clogged up. Second is the purge solenoid is not working. The solenoid could be bad or the wiring. Check engine light on?
Aug 16, 2011 | Lexus LS 400 Cars & Trucks
Gas mixing with oil even while motor is running. whats causing this?
if its smoking alot oil ring on piston stuck in oil passing the piston engine will smoke
Feb 11, 2011 | Karcher 2500 PSI Pressure Washer
IR SS5L5 Won't reach shut off pressure
It sounds as though your unloader valve is stuck or broken. I would try and repair it but otherwise you will have to bite the bullet and get a new switch assembly I think. As you have just been working on the tank it might just be a bit of debris dislodged and stuck in the unloader valve. The unloader should only hiss just after switch off weather by automatic shut off or by manual shut down.
Jun 05, 2010 | Ingersoll Rand SS5L5 Ir Electric...
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
96 chrysler cirrus 2.4 pouring out oil
going to be hard to see but the sensor for oil pressure is located in the rear somewhere close to the oil filter area. find that sensor bad alot. try that
Apr 06, 2009 | 1996 Chrysler Cirrus
360 motor losing oil pressure after15min of running
Try hooking up a mechanical gauge to make sure you have a problem.
Feb 27, 2009 | 2000 Dodge Durango
Air compressor/ alot of air is coming out of the oil cap vent.
this could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
Jan 13, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Karcher 1750 psi Electric Pressure Washer Logo
163 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
