Question about Bunn CWTF15-TC
If I can't get the water t6o come out when the
If I can't get the water to come out when the machhine is on and the start switch has been pressed, how do I get the water out of the machine? It won't come out of the spiggot either. I have put water into the machine twice and it heats up but will not brew.
    President:
  • 1,618 Answers
Try this, use the manual fill in the top of the machine, remove the sprayhead, put an airpot under machine and pour water into the machine at least 3 liters, until it pours out of brew tube. If that works, then the problem lies in the solenoid or the ling bringing water to the machine.
Posted on Jun 18, 2009
I loused up the start-up of my 37 inch visio tv. can i start over from scratch? ted johnson
You can reset it t6o factory standards. Unplug TV and press power for 30 seconds. then plug TV in and go tot menu.
Sep 08, 2011 | Vizio Televison & Video
My washing machhine doesn't wash or rinse it only works on spin
If not filling with water check water is on and fill solonoid valves .
Jun 19, 2010 | Washing Machines
When entering the spin cycle, the motor turns the drum a quarter turn then stops for a second then repeats the process over and over but does not spin?
Hi.
If the machhine is belt driven check the belt first.
If the motor is variable speed the motor must be tested energizing it.
If you have single speed motor with clutch and motor couple system, check the motor coupler.
If this is a top load direct drive, check the transmission.
In all cases test the lid switch to ensure it is not opening contact when machine starts agitating.
If there is a motor control unit, that must be tested.
The wiring harness to motor, and also to MCU if there is MCU must be tested.
If there is no other fault , replace the timer board.
Regards.
Nov 13, 2009 | Washing Machines
Kenmore dryer 75731 won't tumble. It heats fine.
Hi.
The machhine is belt driven check the belt first.
If the motor is must be tested energizing it.
In all cases test the lid switch to ensure it is not opening contact when machine starts tumbling.
The wiring harness to motor must be tested.
If there is no other fault elsewhere, replace the timer board.
Start from the belt, if the machine is heating, then it is probably a broken belt.
Nov 13, 2009 | Kenmore 63942 Dryer
Hi, I got a Fridgiaire front load washer. I got an error code E 41. Machhine won't start at all. Replaced the board. Now water enters machine for 15 seconds then stops will not spin
The E41 error means the control thinks the door is open. From your description of the problem the most likely problem here is a bad door switch assembly.
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machhine takes water and then switches of
check for a weak circuit breaker...we need 15 amps alone...onthejob
Jan 30, 2009 | LG WD-14124RD Front Load Washer / Dryer
Boiling water in Miele automatic W750
Hi,after posting I had the enlightened idea to run the machine again.Gut told me it was a blip,rather than a defect.Has run 2 cycles with no problems recurring.We keep our fingers crosswise!regards henk
Jan 08, 2009 | Miele Novotronic W1918A Front Load Washer
Top thread keeps breaking
i have a singer sewing machhine that keeps breaking the top thread!!! it is not computerized!!! can you help me?
Apr 27, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Bunn CWTF15-TC Logo
227 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
