Question about Infinity BASSLINK Car Subwoofer
My home thearter subwoofer very noisy when i power in?
Hi friends. i have john barrel homw threater i have problem in sub woofer very noisy. problem by me.i connect my old subwooffer with new home thearter sub. thn my old sub is very noisy thn i removed. now my new home theater sub woofer not working very noisy.. plz help me what is that problem??? give me any solution.
2 Suggested Answers
SOURCE: No sound..amp has power to it
After three days of torture, I was going to rip it out, until I decided to make a fresh ground. I drilled a small pilot hole and got a brand new self tapping screw...voila!!! Works like a charm.
Posted on Sep 19, 2009
Hi friends i am using kenwood subwoofer sw-300 its not working from two days, i observer relay triping sound from inside the amp relay omron g5r 2232p-kw 48vdc has continue tripping while power on,
Short circuit protection energizes. Check for any external short circuit with connecting sires to sub woofer. If it found OK, the sub-woofer output amplifier section circuit inside the set is fault. Short circuited component/s. Check and replace them. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 03, 2015 | Kenwood Car Audio & Video
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
Subwoofer noisy when powerd on.
Speaker wires are backwards,
faulty audio or optical cable,
system or cable tv is not grounded
Apr 14, 2014 | Audio Players & Recorders
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Infinity BASSLINK Car Subwoofer Logo
32 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
