Question about Polaroid TLA-04011C 40 in. LCD TV
Multiple vertical colured lines panasonic veire
Multiple vertical coloured lines
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Setup panasonic viera
Yes, it should be possible to "move" the menu-box, by using the on-screen controls.
May 16, 2014 | Televison & Video
Panasonic pt 52lcx66 flashes green turns on and then turns off after 2 min
Need to look at the menu on colur
It will indicate lining up of certain colours
Use the directional arrows to centre the colours
May 12, 2014 | Panasonic PT-52LCX66 Projection Television
Panasonic Mod. TH-42PX6Uwith multiples vertical lines?
Y -SUS or panel have to be suspected.
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Oct 03, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
I brought 3 samsung LCD from harmon house dubai now 3 LCD in india there is one LCD is complaint (comming center line and color change) i told your service center thrissur kerala india but their asking...
The central vertical line in the display is due to the damage caused in the LCD display due to impact..probably during shifting.As result of it the colour mixing fails.
The colour could also fail due to colur IC chips failure too...due to impact or voltage fluctuations.
You will find lot of Purple,& green in the display.
Get it serviced in a authorized center.
Sep 19, 2011 | Televison & Video
Thin coloured lines running down center of tv. Panasonic Viera.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO SOLVE THE PROBLEM.....
Aug 07, 2011 | Panasonic Televison & Video
What is the proper calibration settings for a panasonic tc-p50s2n. I have used it for over a 100 hours
Do you have access to a test pattern or color bar ? .If you have a THX certified DVD ( some Walt Disney movies ) it will have calibration setup guide in the DVD menu.Or else you have to buy a calibration DVD if you are serious about your TV setup.
First you have to set the contrast and brightness using the Grey-scale pattern. Seven set of vertical bars slowly progressing from white to black. If set right you should be able to make out all the seven bars with out each merging ( or overlapping ) into the other. You will be able to see the line of demarcation between each vertical bars. Then set the color to taste.
If you do not want to purchase the above mentioned DVD disc a close setup figure for your Panasonic TV would be
Picture Mode = Standard ( Normal )
Picture ( Contrast ) ---- 50
Brightness ---------------- 50
Color ------------------------ 33
Sharpness ---------------- 50
Hue ------------------------- In the middle
This setting should give you a decent picture quality assuming your TV is new.
Apr 12, 2011 | Panasonic Televison & Video
Problem with panasonic tv
It is usually caused by problems from lead solder that sometimes does not connect, so there are some points of the components that are not connected with lead solder to the circuit. if it appears vertical line means from the IC (integrated circuit ) Vertical, you can solder all the points in the IC ( Integrated circuit ).
Sep 07, 2008 | Panasonic TX-32LX1F 32 in. LCD TV
Polaroid TLA-04011C 40 in. LCD TV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
