Question about Panasonic PT-56LCZ70 56" HDTV
I turn the power on, no picture comes on. This occurrence is erratic. Sometimes the souns and pictures don't materialize at all. What is going on?
  • 35 Answers
CHECK all inputs narrow down your symtom. J.D.W.
Posted on Jun 18, 2009
No picture
Double check when replaced wheel all the plugs went in right---does lamp come on for a moment and then go out?
If lamp never even for a second or two comes on suspect Ballast.
May 30, 2012 | Samsung HLN617W 61" Rear Projection HDTV
Picture occasionally goes out, still have sound when this occurs and then the picture will come back on after a while. When the picture is out the lamp is off. Hd61lpw42 RCA DLP TV
Souns like the Lamp is going out ,If you have never replaced Lamp then that is what your Problem is Mats has them for $99.00 1-800-628-1118
Nov 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
The screen is black. I have sound but no picture.
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
Jun 01, 2010 | Televison & Video
The picture on our tevion television just disappeared. We have sound, but no picture at all. this happened very suddenly in the middle of a news broadcast.
May 26, 2010 | Televison & Video
When u push the power button the tv tries to turn on, makes 3 switch noises and then the power turns off
this is somtimes a bad power supply or fuse if you have sound it likly and no picture usaly a fuse put this seems pretty much like a power supply issue this regulates power from the wall to each component of the tv like the picture and the souns amp
Dec 20, 2009 | RCA D52W136D 52 in. TV/DVD Combo
TV Powers off
tap on the power supply borad not to hard
and have some one let you know if pix fark out
go all thur all the board soune like you have bad solder jonts
Aug 12, 2009 | Televison & Video
60 grand wega 5 years old picture getting darker
souns like an over heating isue
try cleaning out the unit
take it to the local mechanic have him give your tv a ******* (with compressed air )
heck hes been screwing you so his kids can go to coledge for years whynot get a freebe?
Aug 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I had two capacitors in my 50mf231d/37 50 inch plasma tv go out.
your problem is in the Y or Z sustain boards i just fixed one of this today with the same exact problem and i replaced  the Y sustain BINGO.
good luck
caypianan@yahoo.com
May 12, 2009 | Samsung HP-S5073 50 in. Plasma HDTV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
NO PICTURE AFTER FEW MINUTES/DARK PICTURE/ERRATIC/NO MENU VISSIBLE
Most projections have a removable speaker cover on the front under the screen. Then there is an access panel that you remove the CRT sockets are the circuit boards attached to the CRTs
Dec 23, 2007 | Televison & Video
Panasonic PT-56LCZ70 56" HDTV Logo
241 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
