Question about GE Profile Performance 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25PPBWW
Water is leakink out of my icemaker
There was a puddle of water on my floor this has never happened before. food is not that cold but temp setting on freezer is 16 degrees. i look inside of freezer and water is leaking from ice maker and dont feel like its freezing
    Problem Solver:
  • 9 Answers
Depending on the make, year, model and sometimes age of the unit, it could be the start relay and capacitor. Sometimes a power surge, or defective compressor, will cause the system to shut down and stop cooling, but occassionally the start relay will go bad and require simple replacement. Usually when you replace the start relay, it's a good idea to replace the capacitor as well. Upon purchasing these two items, check with the vendor to see if they will accept returns in the event this doesn't work because these two items can run between $80-$100 in some areas. A 3 n' 1 Start Solid State Relay Overload Start Capacitor Combination (Hard Start system) will do the same thing, you just need to know your systems H.P. rating (1/4-1/3 H.P., etc) in order to get the right part. Again, if this doesn't work, your compressor could be shot and the expense of replacing it along with service cost might warrant replacing the old refrigerator-freezer with a more modern system. Plus your home owners policy may cover some of the expense if you can show a power surge from your utility company into an un-protected system caused the damage. If your deductible isn't to high, you can off set the purchase of a new system by filing on your home owners. The average cost for a side by side refrigerator-freezer, depending on cubic feet, could range from $1000-$1700. A dependable service operative is suggested if you are not very comfortable with basic repair techniques, or these simple suggested remedies fail to solve your problem. As always, have your owners manual handy and scope it for ideas on problem solving. *If the food is thawing, you need to cook up what is left if possible, or you may buy some dry ice and place it in the freezer to keep the food frozen for a short period. The amount needed will be determined by the number of cubic feet of your system. Hope that helps and good luck.
Posted on Apr 14, 2014
3 Suggested Answers
sdmc73
  • 121 Answers
SOURCE: Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Posted on Nov 29, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Posted on Apr 19, 2010
About once a week I find a small puddle of water on my floor in front of my Kenmore Elite refrigerator (bottom freezer, no ice maker). What should I do?
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
Oct 02, 2011 | Kenmore Refrigerators
1 of the valves are leakink on the boiler im lead to belive its the pressure 1 not the temp 1 as the water is cold we told the plumber he replaced 1 of the valves unsure which 1
hi i need to know what boiler, all pressure valve work on temp, and what is the boiler do i.e........ does the pressure rise when the heating is on, does the pressure goes up in the red around 3bar???
Feb 16, 2011 | Plumbing
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag MZD2766GES Side by Side...
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
Leaking water on the front corner of the freezer side. We have turned off the water to the icemaker and have turned off the icemaker. Still leaking, not fast, but each day I clean up a puddle.
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket. Look in your freezer floor for ice build up. If you don't see anything like that or if you think the water is coming from underneath the fridge, then it is your condensate pan underneath. They crack sometimes.
Sep 06, 2009 | Frigidaire Refrigerators
Ref. Whirlpool model ED25DQ/ water in meat drawer
You seem to have conflicting information here.
If you turn the therostat DOWN it is setting it to defrost that will not help the food in the door to get cold it gets it warmer. The water is possibly from the fridge being in defrost mode and the tube that usually direcfts it to a tray beneath the fridge to waste tray that evaporates the water from the heater coil has somehow been directed back into the crisper draw.
tfry turning the fridge to colder not warmer. Hope i interpreted this correctly, language is a wonderful tool when facial expression and visuals are available otherwise its a handicap
Jun 21, 2009 | Frigidaire Refrigerator Light Switch -...
Kenmore 106 50522 water leak from Icemaker
Hi: Usually if the ice maker malfunctions that bad it will keep running and flood bad. If your defrost drain is plugged it will puddle water. Without knowing how much water you see it is tough for me to say precisely. Does the ice bin have a big block of solid ice or cubes? If cubes I would guess it is the defrost drain at the bottom of the fridge. If the drain is clogged the water wont get to the pan to evaporate. If the defrost water has nowhere to go it will puddle. This would produce more water on the floor in a humid area than a desert like I live in. If so look at the bottom of the freezer in the back below the metal panel. Usually there are slots above it. There will be a hole at the bottom of a shallow rectangular funnel. Turn off the fridge and put your food in a cooler. Pour some warm clorox water in the hole, a fairly strong solution. It should eat out the mold that grows in the base of this non refrigerated line. If something like a frozen pea got in the line you might have to use a pipe cleaner to snake it out. Good luck with this, Jeff
May 31, 2009 | Kenmore 50522 / 50524 Side by Side...
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
