Question about Sony 182556522 1-825-565-22 SUB WOOFER (PCVA-SB1) Insure proper part number before ordering. Computer Speakers
How to open a Sony Vaio PCVA-SB1 Subwoofer
Removed eight screws (4 from each side) Still can't open. What else needs to be done to open the box. I don't see any other latches.
I consider myself pretty tech savvy but this one has me stumped.
    President:
  • 828 Answers
Call an assistance or technician to help you open your Sony Vaio
Posted on Jun 18, 2009
  • jonas Dec 30, 2011
    Stupid solution. Of course, you'll call the technician eventually. Prior to that, what will you do, stupid.
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
Tip
Infinity bass pro - Circuit diagram
See the circuit diagram for Infinity. sub-woofer. Electro help
on Jul 08, 2014 | Sony 182556522 1-825-565-22 SUB WOOFER...
VGP-sp1
just do as I did cut the cable and attach to a store bought power adapter works good. I am only using a 12v power adapter and it seems to work fantastic
May 13, 2012 | Sony Audio Players & Recorders
How do I change the cabin air filter in my 2009 Nissan Maxima?
If you are quite comfortable working on cars you can do this. The in cabin air filter is accessed through the glove box opening after removal of the glove box.
There is a small panel covering the right hand side of the glove box which will pop off if you pry lightly with a standard screwdriver
Then there are eight philips head screws which must be removed. Three are at the bottom of the glove box, three more are inside on the top and two are located inside at the rear top of the glove box. Once these are removed and the glove box is pulled out the filter is accessible, but not very easily seen.
It is located on the far left side and covered by a black plastic cover. You can reach in and push up lightly on the plastic cover removing it.
The opening is smaller than the filter and that makes removal and replacement difficult, but the filter is flexible and the pull tab can be used to extract the old filter. The new one can be squeezed and pushed into place with the air direction arrow towards you (the same orientation as the one removed). Replace the plastic cover and reinstall the glovebox by installing the eight screws and the side cover.Thanks for choosing Fixya,
RJ
Read more: http://wiki.answers.com/Q/How_do_you_replace_cabin_filter_for_2009_nissan_maxima#ixzz1MYGWxc6K
May 16, 2011 | 2009 Nissan Maxima
Remove keyboard
You need to locate screws below you laptop, the keyboard was ajusted by some screws(2-4), Vaio do this in almost all models. Detach your screws and your kb will be removed.
thanks
vcrtech
Apr 20, 2009 | Sony VAIO PCG-GRT100F PC Notebook
Sony subwoofer PCVA Sb1 doesn't work most of the time.
check the cables- sharp sound b4 disconnect is mainly due to power cut or cabling problem
Feb 04, 2009 | Sony 182556522 1-825-565-22 SUB WOOFER...
How to RAM upgrade sony vaio BZ
just open the back side...not fully ...look for 4-5 screw tightened a cover open that..there u can replace exactly like before...
Dec 04, 2008 | Sony VAIO VGN-BZ560P22 PC Notebook
Display problems in sony monitor pcva-15xa3
hey bro.. download mo security update ng sony vaio then install mo.. masol2ve nyan display problem monitor mo...
Mar 03, 2008 | Computers & Internet
Disassembly manual
Hi, every desktop pc is almost the same to open up and take apart nowadays, if you want to checkout some of these videos should give you more than enough info..
http://www.youtube.com/results?search_query=disassemble+pc
All the best
John
Jan 02, 2008 | Sony VAIO PCV-W510G PC Desktop
1,876 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
