Question about HP Compaq nc6000 Notebook
Hp compaq nc600 does not come on
The orange light and processor fan comes on for about 10 to 15 seconds and goes off. i have change the ram, remove the battery and remove the hard drive but the problem still persist.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
Is it still under warranty, if so i would send it back, because these are all the simptoms of a dead or damaged motherboard. These are all expensive to repair, so i would look to buy a new laptop, maybe the same model, so the hardrive can be added to the new computer to prevent data loss.
Good Luck, Sorry It Happens
Posted on Jun 18, 2009
    President:
  • 828 Answers
Hardware connect improperly inside... open it.. and remove the lithium battery to reset bios settings...
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
I have hp compaq nc6000 every time i switch it on it comes on and goes off within 5 to 10 seconds. there is no display when during yhat time. what could be the pssible cause
From the description this is a motherboard issue, a common problem with hp, at this point I would recommend having it assessed.
Jul 20, 2012 | HP Compaq nc6000 Notebook
HP COMPAQ NC6000 WONT COME UP; FANRUNS AND ORANGE LIGHT FOR ABOUT 5 SECONDS AND THEN SHUTS OFF EVEN ON AC POWER OR BATTERY.
Hi DD,
Does the cursor blink on the screen before turn off?
There could be several causes for your PC's problem.The major ones though are:-
  1. A virus invasion of your PC.
  2. Your Operating System/boot log has corrupted.
Turn on the PC and press f8 on startup.Select to open on safe mode.Choose to open on a previously good working Operating System.
If this works and the PC opens,you may have to transfer your important files to an external drive then try repairing the Operating System or probably re-install it again.But first:-
  • Check the RAM[s] and make sure they are properly seated in their slots.Your Notebook has 2 memory slots under the keyboard positioned one on top of the other.The expansion slot is the one on top of the primary memory slot.Access them by flipping over the laptop and unscrewing the back cover.There in the middle is the only compartment housing the RAM[s] and the PC's CMOS battery.Unscrew.Remove the RAM[s],clean their slots and the fix them again making sure they properly fit.
  • Check the hard disks power supply.Disconnect it and re-connect it again.
Hope this helps.Thanks!
Nov 13, 2011 | HP Compaq nc6000 Notebook
HP Compaq dx2000 Microtower PC not starting up properly, the orange light keeps flashing on the front and nothing on the monitor. Tried unplugging everything, depressing button for 5 seconds...nothing...
Are you sure it's not red you're seeing instead of orange? Disconnect power. Re-seat the RAM circuit boards inside the computer. Check for possible loose parts inside. Check all the fans and remove accumulated dust. Check the CPU - if possible remove the heat sink and inspect the silicone compound for dryness - reapply new compound if it's dry. The power supply may be bad as well - check that.
Nov 11, 2010 | HP Compaq dx2000 Microtower PC Desktop
Hp dv 6000 had a burnt resistor bythe battery, the pwer plug would light but nothing else, changed the motherboard and now the buttons light up and fan turns on for about 2 seconds then shut off again......
ram, processor, battery bad, its a long list but try changing the ram first, also make sure the processor fan has enough heatsinc goop. and the fan is pluged in, re seat the processor if this dont fix it better take it to a shop. well one last thing check that the cd rom is inserted tight.
Apr 12, 2010 | HP Pavilion dv6000z PC Notebook
My compaq nc6000 freezes after about twenty mins. I switched memory and harddrive but no change. it's not power options
JUST TURN YOUR LAPTOP AND CHECK IF YOUR PROCESSOR FAN IS WORKING, YOU SHOULD FEEL SOME WARM AIR COMING OUT FROM IT. IF IT IS NOT WORKING THEN CHANGE YOUR FAN...OR IF IT IS WORKING, TRY TO CHECK YOUR PROGRAMS AND HARDWARE IF THEY ARE CONFLICTING, LAST THING IS TO CHECK YOUR PROCESSOR, RAM JUST TO MAKE SURE IF ITS NOT A PROBLEM...CHECK OUT
Oct 16, 2009 | HP Compaq nc6000 Notebook
Computer won't boot up
Check the heat sink connected on your processor and its cooling fan is working or not
Apr 09, 2009 | HP COMPAQ Presario SR5410F Pentium...
HP Compaq nc6000 Notebook Logo
784 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
