Question about Stamina Products Stamina - Air Rower 35-1399
Air rower 1399 won't unfold completely, main rail is being obstructed by stand ... Product only 2 weeks old
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
I have a 2 yr old dehumidifier and it runs, it just won't pull out the moisture out of the air.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(No LED screen), set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you and thanks for choosing FixYa
Sep 13, 2011 | Kenmore 938060 Humidifier
Our maytag bottom freezer was left open on a crack and it thawed and then froze up... We emptied it and shut it down to thaw out. we dried it too, but the freezer is hard opening and closing . any...
HI,
The rails got water in them and froze. The only way to correct this is to remove them, allow to dry completely, like 1 or 2 days. Re install them and it should be fine. But the down side it the door won't stay closed during this process. You can order new rails but your rails aren't defective. It your option to elect which one of these you wish to do. If you are under warranty, have them replaced with new ones and keep the old ones.
I hope this helps
Aug 17, 2011 | Maytag Refrigerators
Our Kenmore 50pt dehumidifer is less than 2 years old, only used for 1 summer, tried to use it last week, it starts/runs but does not withdraw any water, please help. Thanks kindly
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you unit is manual control,
turn the control knob to Maximum.
the unit without the filter. Filter should be cleaned once every 2 weeks.
level
problem.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Humidifiers
The vacuum keeps falling over and won't stand upright. The vacuum won't **** from the bottom, only from the hose in the handle.
No Vacuum will work for more than a few weeks
if you don't own an air compressor & blow them out
after every 2 or 3 uses
May 29, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Looking for a manual for an old lifestyler (weslo) rower and x/c skier exercise machine, number 831/29044
You may have to call iconfitness.con since this is their product, they may have the manual in their Dungeon call them @ 1800-999-3756 GOOD LUCK!!!
Jul 10, 2010 | Exercise & Fitness
My integrity air 3000 has a elastic like cord attached to the underside to the chain. The elastic cord is now unraveling. Where would I get it repaired? I live in Columbia, Missouri. Thanks, Patti O.
Call Fitness Qwest at 800 321-9236 for the part. They will need the serial number of the machine (on the back stand underneath. All of the parts are easy to replace. It is an easy machine to work on.
Jul 05, 2009 | Fitness Quest Integrity 3000 Air Rower
The chain has become completely loose and will not recoil, ?
You didn't say what model you have, but I believe they are all functionally similar to my Model B rower. There is a "skewer" assembly inside the seat rail with a shock cord and pulley's that keeps tension in the chain throughout its range of travel. To some extent it is adjustable by taking slack out of the shock cord. On mine, this can be done by grabbing the shock cord adjustment mechanism ("SCAM") with pliers and pulling it out of the rear of the machine and adjusting the slack. If it is very loose or you just want to be sure of what is going on, the entire skewer assembly pulls out from the front (flywheel side) of the seat rail after removing four screws that hold it in place. Go to the concept2 website for diagrams, instructions, and parts lists for your model.
Jan 18, 2009 | Concept2 2 Rowing Machine
How do you unfold and fold a quinny buzz
Hi to unfold undo the clip if there is 1, some don't have them. lift the handle slightly then it should unfold it self.
To fold you need to apply the brake, stand in frnt then the 2 large grey buttons either side of seat, 1 pushes in 1 comes forward, do this & pull down towards your feet this will fold it up. Don't mistake the small grey buttons on side of seat they are to lay seat back/forwrsd etc; the large buttons are on the frame.
Oct 08, 2008 | Quinny Buzz Jogger
Stamina Products Stamina - Air Rower 35-1399 Logo
23 people viewed this question
Top Stamina Products Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
