Question about Sony KDF-50E3000 Television
Replaced bulb and still fuzzy and dark
Got a new bulb and it is still very dark and not real clear
  • Just right Auto Repair
    Just right Auto Repair Apr 29, 2014
    Hi Donna Keegan,my question for this problem is did you clean the screen while you had it apart, and if so did you wipe it down with Windex or some kind of cleaner?
Changed dlp chip in mitsubishi 65735 tv the picture isnt real clear when i put on screen menu on the writing is real fuzzy have taken apart sevral times just to make sur e i did it wright
Remove the lenses in front of the bulb and carefully clean them with a soft cotton cloth. NEVER use paper to clean a lens. It will ruin the lens by scratching the surface of the lens.
Dec 30, 2014 | Mitsubishi Televison & Video
Dark, fuzzy picture
The fluid in the CRT bulbs is most likely cloudy. Check the blue to see if fluid is clear. If fluid is clear, then likely your flyback transformer is failing. I assume you already check the brightness and contrast settings on the tv.
Feb 18, 2011 | Toshiba 57H81 57" Rear Projection...
Can not focus. The lens moves fine from one end to the other but I'm unable to see clear images with or IR while in a dark room.
Don't IR illuminator in the dark room. Turn on a small light in one of the corner; such as, a small light bulb. increase ambient light a little at a time until you can focus. You flooding the dark room with IR illumination which will reflect everywhere in there. This might take care of the fuzziness in the monocular. stewbison
Jan 29, 2011 | Yukon 24021 Monocular
LG Plasma screen just went nuts
It could be any of 4 boards, either take it in for service or get a new set.
Nov 16, 2017 | LG 42PC3D 42 in. Plasma Television
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Refrigerator light doesn't work
then tyr and replace the door switch on the refrigerator side. they are relatively inexspensive to buy and are real easy to replace.
Feb 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fuzzy picture on Quickcam chat by Logitech
I can tell you how to fix it :D the white part where the lens is turn it ontil clear my dad did it for me its soooo clear! This is when its dark...e6c1bca.jpg
Mar 22, 2008 | Logitech Quickcam Chat Webcam
The picture shows dark
Hi there
Take out the Projector's lamp and check for any black marks ( almost looks like veins ) on the inside of the bulb.
If you spot anything on the lamp , your lamp will need replacement.
If you can't see anything - then you might be in for a new Mainboard.
Very expensive exercise !
Mar 11, 2008 | NEC VT47 Multimedia Projector
Sony KDF-50E3000 Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
