Question about Health & Beauty
Rascal 245 wiring diagram
My scooter just stopped working. Batteries are fully charged,battery indicator shows 'F' on the Green side, but NO motor functions. (Either Seat Motor, or Propulsion.) Circuit breaker and Tiller/Throttle controller are good. (Both work when switched to my other scooter.)
5 Suggested Answers
  • 177 Answers
SOURCE: Invacare Zoom 220 mobility scooter will not run
Hi. When the machine is on, does it display a flashing light or LED on the display for a fault code? Is the free-wheel lever switch operating correctly?
You might have a sticky brush in the motor. Take the brushes out and check their condition. If the brush caps are not tight enough then the current arc's on to the side of the brush, and it jams in the brush holder.
Check the resistance through the motor before touching the brushes. Check motor and battery connectors for continuity and any sign of heat or melted plastic. Check operation and resistance of the brake unit. Most controllers in mobility scooters are quite reliable, so always eliminate all other possibilities before looking at the controller. Good luck. Neil.
Posted on May 29, 2010
  • 692 Answers
SOURCE: will not go. ohm wiring
me tool time you checked or changed about everything but did you check the electric brake. Sounds like the brake is not working or is working intermittentaly. The controller needs to get the right reading from the brake or the scooter will not go and when you release the throttle the brake should engage immediately. I can't give you a well thats the answer but you should at least ohm out the brake. If you can call rascal Company on Monday and ask for tech support they can give you what the reading should be Hope this helps
Posted on Sep 18, 2010
HoverTech
  • 232 Answers
SOURCE: I have a 240W electric
Make sure that the manual brake release/freewheel lever is enaged as if it is not, this will allow you to push the scooter, but will not engage the drive motors. It is usually located on the rear of the vehicle; check your owner's manual.
If this does not work, contact the manufacturer for additional troubleshooting.
Posted on Oct 25, 2010
batvette
  • 16 Answers
SOURCE: rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Posted on Sep 01, 2012
Getting a 250 Rascal Motorized Scooter to run when battery indicator shows green. Is there a safety feature that we are unaware of?
If you leave the battery charger plug in the charging port the scooter will not move. If the disengagement lever is not engaged the motors will not run either.
Oct 13, 2016 | Health & Beauty
Rascal 245. wont work. new batteries. i wired srtraight and motor works. power going to the box under seat but not out
The motor controller may be bad. If the battery charger is connected to the charge port , the scooter won't move even if the charger is not plugged into the wall.
Aug 22, 2016 | Health & Beauty
Rascal 230 wiring diagram
Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
Oct 09, 2014 | Electric Mobility Rascal Scooter...
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Rascal 600
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Low hour, RASCAL 600 has been in clean safe storage with new batteries won't charge, no amp meter reading, no fuel gauge reading, yet charger itself has red and green light showing. If and when the...
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
May 08, 2011 | Health & Beauty
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Mar 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
Health & Beauty Logo
29 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
