Question about Kenmore Dryers
Lady Kenmore Dryer has an error code AU, when trying to dry on Cotton Setting
Jimster
  • 240 Answers
SOURCE: Kenmore dryer codes
That means you are in the automatic cycle, or what is used to mean. Pretty sure it still means that. Jim
Posted on Sep 07, 2007
  • 146 Answers
SOURCE: kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Posted on Dec 22, 2007
  • 148 Answers
SOURCE: Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Posted on Jan 05, 2009
GM Elec
  • 1000 Answers
SOURCE: I HAVE A KENMORE 110-67082600 DRYER AND I AM GETTING F44 CODE
The F44 fault code indicates a blower motor control electronics failure. This can be caused by a wire harness connection problem between the machine electronic control board and the blower motor electronic control board. You will normally need a technician to diagnose and repair this type of failure. If you have the technical ability to safely access and check internal components in your dryer I can include the diagnostic portion of the manual.
Let me know.
Regards,
Posted on Jul 28, 2009
milten1
  • 1304 Answers
SOURCE: Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Posted on Oct 06, 2009
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
The heating element in my Kenmore dryer, model number 110.63032101, does not fully heat up sometimes. With the setting on cotton/high the element will sometimes be fully illuminated and sometimes only...
no,that's how they run,if your clothes are drying and the dryer is cycling on and off,leave it alone,if the clothes are taking a long time to dry clean out the duct that the lint filter slides into and blow out the vent line with a leaf blower if it's a long run
Oct 12, 2010 | Kenmore Dryers
Dryer runs for about 5min (has heat ) then stops, error code E1
usually that means you have a bad thermistor.
try setting it to low heat timed dry
how long does it run?
Aug 28, 2010 | Kenmore Dryers
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Dec 28, 2017 | Kenmore Elite HE4 Electric Dryer
I want to remove the heating element from a Lady Kenmore dryed # 110 76694100. How do I access the element and where is it located?
Should be located in the back of the dryer...remove the panel from the back of the dryer, and look for the dryer air tube coming from the fan...the element should be in there
Sep 22, 2009 | Kenmore Dryers
The gas dryer ignites with small flame but does not fully ignite when set to high cotton setting
you need a dryer conversion, it sounds like it is set up for lp gas
May 17, 2009 | Dryers
Kenmore dryer 417.84072300
Dec 04, 2007 | Kenmore 84072 Electric Dryer
Dryers Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
