Question about Magic Chef Refrigerators
Frig keeps shuting off reset button
Why does frig shut off and has to be turned back on with reset button
3 Suggested Answers
  • 351 Answers
SOURCE: My Whirpool fridge keeps shuting off. It will
sounds like a loose connection maybe, could be the cold control as well
Posted on Jun 23, 2009
  • 100 Answers
SOURCE: compressor keeps running. Hasn't shut off in last
Good chance your FREON or refrigerant has developed a leak. To save money, put your unit in the back of your truck or trailer and take it to a REFER shop and have the Sealed System Checked. They will tell you if it can be recharged or if you Compressor has died. If the compressor has died, generally it means the unit is too expensive to fix. Reason, the cost is high, the recapture of the GAS before it is recharged in expensive, the compressor is expensive, and the recharging is expensive and then putting a new compressor in a older refer could put a lot of pressure on a group of existing old parts... well then, the weakest link will generally break... Not always, but if one does, then your into a older refere and stuck with pouring more money into older unit.. Sorta like pouring money into a hole in the water... They call that a boat... Hummmmm Good luck.... e8dcb4e.gif
Posted on Dec 01, 2009
When the screen is white instead of taking out the battery and putting it back in can I do something else?
Not sure why your removing the battery?
If you are shuting down the machine. Close all running programs before shuting down otherwise the machine has to close each program in turn before thr machine can shut down all together. Depending on how the settings are for the power button. The shut down process can be forced by holding down the power button until the machine has shut down. Black screen instead of white. Hope this helps answer your question.
Regards
Bob from OZ
Jun 15, 2015 | ProntoTec ntoTec 7 Inch Android Tablet Pc,...
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
D-Link DSL 2750B Modem/Router keeps shuting down ?
Try a factory reset. login to your router and under setting go to factory reset. Once done you will have to set-up you device from scratch.
Jun 03, 2012 | D-Link Computers & Internet
We moved our magic chef frig on the deck-plugged it into an outlet with too many thing running. The breaker tripped.Not the frig light comes on but the frig does not work. Is there a reset button? If so,...
There is no reset button.
Firstly turn the fridge off at the wall switch. Wait 5 minutes then switch the power back on. If the fridge still does not start then you have a problem with either the fridge electrical circuit has a fault or the circuit board fuse has blown.
Apr 01, 2011 | Magic Chef CTB1722 Top Freezer...
Jun 23, 2009 | Refrigerators
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Shut off
Does it shut off immediately after turning on? How long after it has been on does it shut off? Can it be turned back on immediately or is there a "cooling" period where you have to wait before it can be powered.
Is this a TV under warranty or is it out of warranty? If in warranty, simply contact RCA and they should help you out.
Mar 28, 2008 | RCA TruFlat 27F520T 27" TV
My rt2280
the quick answer is turn it off from the power button, then press the dvd button or whatever button you are using.Do it twice if it needs it.
Mar 13, 2008 | RCA RT2250 System
Refrigerators Logo
20 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
