Question about Garden
My honda excel 2600 psi pressure washer do not have any pressure when i squeez the trigger
    Scholar:
  • 90 Answers
Trash in, worn or damaged inlet and outlet valves are one possibility. Unloader valve stuck open or badly worn would also cause low pressure. Wrong spray nozzle size is another. Is the nozzle the right size for your pump?
Is water leaking from under the pump? That would show worn high pressure seals.
Posted on Apr 27, 2014
  • 83 Answers
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
deme-tri
  • 90 Answers
SOURCE: no water pressure on my honda 2600 excell ic2
you need to check the valves,
there is a possibility that the springs are rusty.
Posted on Dec 03, 2009
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
SOURCE: pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Posted on Sep 03, 2010
Excell 2600 psi won't rev High when I pull the trigger
clean out the nozzle jet
replace the pressure regulator
Aug 06, 2016 | Garden
Honda 2600 psi pressure washer
are you sure when the old pump went bad it didn't plug up the nozzle and or trigger
Jun 06, 2012 | Garden
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
I am trying to disconnect the lower hose on this unit is a quick disconnect or does it screw off
If it is the trigger hose, more than likely it will screw off. You may need to squeeze the trigger to release the pressure in the hose. Then it should screw off.
Jan 28, 2011 | Simpson PS3200 Powershot 3200 Psi Direct...
I have a excel 2600 psi and there is no spark, the engine is a Honda
could be many things...get a new spark plug...check plug lead not rubbed and shorting out on body...take flywheel off and check/replace cdi...or points if it has them.
Jul 24, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
234 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
