Question about Great Lakes Spas Pool & Spa
The spa is running too much
The spa gets up to 103 and keeps running.I have it set to that.
  • 3 Answers
When the temp drops 1 degree, it will begin to heat up again. you may need a better cover, especially if it's cold outside. i would set it lower (like 100) and then when you know you are going to use it, turn it up and give it an hour or 2 to heat up...i used to have a timer on my old one and i loved that bc i had it set to heat up each night "just in case i wanted to use it"
Posted on Apr 16, 2014
My spa temperature light is blinking. It is set at 104 and the temperature is showing 118. Why is the temp blinking?
If you can contact your spa manufacturer they will usually send you the manual for your unit at no cost.
If the temperature is set at 104 it is at the high end of the safe temperature for a human. 102 is recommended, and 103 is OK for 15 to 20 minutes maximum.
If your spa is actually at 118 degrees, it could easily cause very severe medical heat distress. I would strongly recommend NOT using it until you can get the temperature down.
It's possible that the blinking light is a warning.
Jun 14, 2015 | Intex Pool & Spa
I am unable to lower the temperature on my dreammaker spa
Is it because the buttons are not responsive?
or is the set temp at 100 but just not dropping in actual water temp?
if former, bad control panel.
if latter, allow time to cool?
Mar 15, 2015 | Pool & Spa
Spa will not get up to temp I set it to 103 and it only gets to 91
Go to a Pool & Spa Store & take your
owners manual, etc & discuss it there
91 may be a default setting when the pump is off
& it is not used,so you may have a problem
Nov 06, 2014 | Pool & Spa
How long should it take to heat spa only
20 to 30 minutes.
if this is a pool and spa combo system, then you are not only sucking water from spa and returning only to spa!
you have a incorrect setting of the valves. It needs to be 100% suction from the tub, and 100% return of water to the tub.
May 15, 2014 | Pentair MiniMax 100 Aboveground 100,000...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
My heater get's up tp 103 then it shut's off. How
104 is the hottest you are going to get it no matter what you do, at least with a thermostat made for a hot tub. It is the highest temperature allowed due to safety (health) reasons. Most thermostats are accurate to +/- a degree, so 103 sounds like the highest you are going to get it. Your only alternative is to try and rig the control circuit but I doubt anyone would want to encourage that since it involves circumventing the features in place to ensure the tub is safe.
Jan 12, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
We only use the heater for the spa. When we used it the other night, the water warmed up but didn't get hot. It said temp was 99 on the heater, but the thermometer in the spa said it was only 86. The...
Water temp sensor. Plugs into thermostat board and follow wires around to the main water header, there it should slide into the header. It will be a small tube connected to the wires. The new one will slide back into place, run wires back to the front of heater and plug back into board.
Jan 09, 2010 | Pentair MINIMAX NT TSI IGNITER
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to hottubbob2@aol.com for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Pool & Spa Logo
105 people viewed this question
Top Great Lakes Spas Pool & Spa Experts
J.D. Browning
J.D. Browning
john h
Jay Finke
Jay Finke
Are you a Great Lakes Spas Pool and Spa Expert? Answer questions, earn points and help others
