Question about Refrigerators
Control panel failure
Hi I have an Admiral fridge / freezer (mod/no Gc2224GEKB ser/no 10285638EX ) and I replaced the water filter, I then pressed the lock and water buttons for three seconds as per the instructions. All the lights on the front control panel have gone off and nothing responds when any of the buttons are pressed except when pushing a glass against the button for the ice dispenser the motor in the ice dispenser kicks in. I can't think what I have done to upset the panel and I hope you can help please? Kind regards Dave
  • Ronnie Snyder
    Ronnie Snyder Nov 06, 2014
    What was the problem? Mine has done the exact same thing
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Have you tried unplugging and plugging the fridge back in? This may reset the control baoard.
Posted on Apr 13, 2014
Testimonial: "Thanks for the advise. Yes! I have done that several times hoping it may work. The problem started after changing the filter and the lights went out over a few days"
  • 2 more comments
  • Dave Blundell
    Dave Blundell Apr 13, 2014
    Thankyou all who have shared your problems and their results!
  • Dave Blundell
    Add a CommentThe problem I have is a little more complex, possibly with a faulty pcb?
  • Ty Roshdy Apr 13, 2014
    That is possibility. But the first thing to do is try the unplugging trick first
  • Dave Blundell
    No one likes Monday, and I am determined to get to the bottom of this problem. Starting with ameter to check if there is power getting to the pcb, then checking if the solenoid valves are ok,next -wel I will cross that bridge when I get there . Thanks again to all......dave
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Posted on Jul 13, 2008
  • 219 Answers
SOURCE: Maytag Freezer Door Panel Locked
replace the front board but read your manual first because some lock without it saying it has the lock feature by hitting 2 buttons for 3 sec at the sametime locks and unl;ocksit
Posted on Mar 19, 2009
abhishek33
  • 1239 Answers
SOURCE: Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Posted on Jul 01, 2009
  • 74 Answers
SOURCE: Front panel beeps when I push any button or
possible bad dispenser board
Posted on Nov 17, 2010
I have an admiral gc2224gekb side by side. The ice machine isn't producing ice and also the fridge is freezing up
First, check to see if the airflow is blocked at the back of the fridge compartment as this also may cause the lower items to freeze. Fridge freezing is usually the malfunction of the damper swing door or the circuit controlling it. A failure of the temperature sensor in the fridge could be the cause. We just had ours replaced this year [on extended warranty]
Sep 22, 2016 | Admiral Refrigerators
Hi i have a fridge freezer model no GC2224GEKB,i have noticed that the refrigeration side has started to freeze even though i have it set to 3oc.
I just answered the same question so I've copied you into it hope you don't mind.
A common problem to this is the damper (vent from freezer) is bad or just stuck open, try defrosting it and adjusting the position so that you reduce the amount of cold air going into the fridge, hopefully it'll just be stuck in the open position and you well have no further problems. Always here to help.. Richard.
Jan 19, 2011 | Maytag Admiral Top-Freezer Refrigerator
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 03, 2009 | Refrigerators
hi,,
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
My fridge freezer has stop working but if you open the door it start to work but if you shut door it stop's and you can hear the fan in freezer stop and start it's a admiral gc2224gekb side by side
Hi thanks for te question. it should be the opposite of what its doing did somebody work on this fridge before. it looks like somebody switched the light and the fan switch
Oct 07, 2008 | Admiral Refrigerators
The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Aug 19, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
